HELP with fuses
Discussion in 'Audio & Video' started by JK4, Jul 18, 2009.
  1. Jul 18, 2009 at 11:19 AM
    JK4
    JK4 [OP] Member
    09 PreRunner Double Cab
    ok i have a jl audio 300/2 watt amp with 8 awg cable. the amp kit came with a 40A AFS fuse.
    the fuse blew yesterday and im looking to buy a new ;one.
    i bought a 80A fuse today for a few dollars and i am wondering if i can use that without causing any damage to my battery, amp cables or my actual amp???
  2. Jul 18, 2009 at 11:27 AM
    montgomery_30824
    montgomery_30824 Well-Known Member
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    K & N airfilter, custom built 10" sub boxes, pioneer head, mag-lite mod, Blue LED dash lights, custom painted engine cover, mud flap removal mod, alarm/remote start installed,
    NOOOOOOOOOOO!!!!!! only use the rated fuse. any bigger and you could risk blowing up your amp. any smaller and you will go broke on fuses.
  3. Jul 18, 2009 at 11:30 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Only replace fuses with the same size that was there before.
  4. Jul 18, 2009 at 11:44 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    WRONG
    All of you.
    You're fusing to the max amperage of the cable. The amount right under where the cable melts its jacket and catches something on fire. Thats when you want the fuse to blow. For 8awg, ampacity is at 75a. Fusing with an 80a might be pushing the limit of safety if the run is longer than 8ft. You can safely fuse up to 60A on anything longer than 8ft.
  5. Jul 18, 2009 at 11:50 AM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    so ur saying disregard when the amp says the fuse rating is and use what fuse if for the size of cable?? always thought the fuse was to protect the component, not the cable.
  6. Jul 18, 2009 at 11:59 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    so say he had 4 ga wire should he put an even larger fuse.:confused:
    I think not, go with what the anp manufacture recomends.
  7. Jul 18, 2009 at 1:23 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
    Johnecon2001 is correct. The OP is replacing the fuse in the power cable. That fuse is meant to protect the cable and the vehicle, not the component (amp). The fuse in the component protects the component. If the OP had a fuse blow on his amp, then he should replace it with the same size fuse that the amp originally came with from the factory. For the power wire, an 8awg cable should have around a 60A fuse. 4awg I stick with 80A, but the wire has ampacity for more current. 80A's are just easier to find.
  8. Jul 18, 2009 at 2:00 PM
    senna
    San Jose CA.
    I stand corrected. this fuse would be located close to the power source, not close to the amp, correct, the amp really is irrelevant in this case.
    I was misled by to OP.
  9. Jul 18, 2009 at 2:52 PM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    the fuse should be no bigger than the sum of all fuses on that circuit. so if the only thing on the line is the amp then go with what the amp is rated at.
  10. Jul 18, 2009 at 3:09 PM
    sooner07
    A A Ron
    DFW, Texas
    While this can serve as a good rule of thumb, it is not sufficient for proper fuse selection. If wire up 4 1000w amps on a 20' piece of 8 awg, you can easily have more fused capacity in the amps than the power wire can safely handle. This is a bit of an exaggeration, but the point remains. You should pick the fuse that properly protects your power wire. It is not meant to protect the components that are powered by the power wire.
    That being said, having a fuse that is under the ampacity of the wire and no larger than the sum of the fuses on the circuit can put a good constraint on what to purchase.
  11. Jul 18, 2009 at 3:26 PM
    TacoNut
    Adam
    Denver, Co
    This is correct. Why play with Fire -literally- if you don't have to??? The manufacture doesn't just pull an arbitrary amperage out of it's ass for fuses. The fuse provided will be plenty to provide the nescicary amount of current to power the device.
  12. Jul 18, 2009 at 4:19 PM
    johnecon2001
    Phoenix, AZ
    You're not understanding the point.
    The fuse is there to protect the wire, if the amplifier total current draw is more than that wire/fuse combo can handle, it's time to move to a larger wire. With a larger fuse.
  13. Jul 18, 2009 at 4:24 PM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    and this is where common sense comes into play. don't wire your amps up with too small a gauge of wire. and i am sure he's not running thousands of watts of power so I am sure that 8 AWG is plenty big enough for his purpose. so again, stay with the rated fuse for what you are running and not what the wire is rated for because that will, in most cases, be too large of a fuse to protect anything.
  14. Jul 18, 2009 at 4:27 PM
    johnecon2001
    Phoenix, AZ
    The fuse is to protect the wire from shorting out, not the amp. The amp has it's own fuses to protect itself.
  15. Jul 18, 2009 at 4:43 PM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    ok. just leave my truck alone.
  16. Jul 18, 2009 at 4:58 PM
    sooner07
    A A Ron
    DFW, Texas
    Did you miss the sentence after what you bolded? It was an exaggeration of the point. But the point still remains valid. The inline fuse (which should be no farther than 18" from the battery) is there to protect the power wire. It is not meant to protect anything else.
    If you have properly fused components that draw more power than the power cable can handle, or you have a short, the inline fuse will go before the wire gets so hot that it catches things on fire. The maximum size for the inline fuse should be based on the ampacity of the wire, not what is drawing power from it. The minimum size for that fuse can, and wisely, is based on the total current draw of the components drawing power from that wire.
    Common sense should say that you want power cable that is safely capable of carrying the amprage draw from the amps or what ever you are powering with it. The part of that safety is a fuse that is below the ampacity of the wire.
  17. Jul 18, 2009 at 5:02 PM
    johnecon2001
    Phoenix, AZ
    Don't worry. I don't do installations for a living anymore :rolleyes:
  18. Jul 18, 2009 at 5:06 PM
    sooner07
    A A Ron
    DFW, Texas
    I can see why. Who would want a properly fused vehicle anyway? :rolleyes:
  19. Jul 18, 2009 at 5:08 PM
    johnecon2001
    Phoenix, AZ
    Indeed. :eek:
  20. Jul 18, 2009 at 5:12 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    johnecon, and sooner are 100% correct here, and frankly, I can't see why anyone would be arguing with their statements.
    This is about as basic as it gets, and if you cant understand the fundamentals, you probably should not be installing your own audio equipment.
