Help With Gear Ratios and MPGs
Discussion in 'Performance and Tuning' started by Cortland, Sep 8, 2011.
  1. Sep 8, 2011 at 1:15 AM
    Cortland
    Cortland [OP] Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I currently have 265/75/16 Duratracs on my V6 Prerunner and would like to get some Camburg spindles but don't want to run 265's with a lift that large so I am debating which set up will get me the best MPG's...
    Would someone who understands gear ratios please put the following options in numerical order of best to worst MPG's?
    265/75/16 w/ 3.73's
    265/75/16 w/ 4.10's
    285/75/16 w/ 3.73's
    285/75/16 w/ 4.10's
    255/85/16 w/ 3.73's
    255/85/16 w/ 4.10's
  2. Sep 8, 2011 at 1:39 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
  3. Sep 9, 2011 at 1:48 AM
    Cortland
    Cortland
    California
    Thanks Randy.
    Any other input?
  4. Sep 9, 2011 at 7:15 AM
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    Temecula
    I would be careful with that calculator. I know that my speedo/rpm don't match what the calculator states. @ 65 with my 265/75-16 my rpm's are sitting at 1940. The tire calculator shows my rpm's should be ~2574 :confused: I tend to think that this is a good calculator to use.
  5. Sep 9, 2011 at 7:26 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    I dont have hard facts for you on this, but i would imagine that if you just kept your stock gears and went with a skinny 33" tire, you could get some pretty good highway mileage by keeping the RPMs lower than stock while keeping your tread to pavement contact as low as possible too.
