help with hella 500 FFs
Discussion in 'Lighting' started by MiikeyD, Jun 11, 2009.
  1. Jun 11, 2009 at 10:16 PM
    MiikeyD
    MiikeyD [OP] The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    alright guys. as some of you may know i put some hella 500 FF's in and wired them according to the stupid diagram. AND THEY WONT TURN ON! im pretty effin sure it is wired correctly unless the diagram is wrong itself but crap it just wont turn on! I also dont understand why the green wire has to be wired to the high beam.
  2. Jun 11, 2009 at 10:22 PM
    MiikeyD
    Upland, CA
    someone?
  3. Jun 11, 2009 at 10:27 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Do you have a good ground?
  4. Jun 11, 2009 at 10:49 PM
    MiikeyD
    Upland, CA
    yeh i grounded it to like a gazillion different things :[ or should i just keep trying. is the connection to the high beam necessary also? i connected it but im just wondering if it is
  5. Jun 11, 2009 at 11:04 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Can you show us the diagram?
  6. Jun 11, 2009 at 11:05 PM
    MiikeyD
    Upland, CA
    damn its in my car. and im in the library studyin.. well supposed to be . heheheeheh
  7. Jun 12, 2009 at 12:31 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    i wouldn't run it to your high beams just to a separate switch.
  8. Jun 12, 2009 at 12:34 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    X2
    and fwiw atleast 8 out of 10 timee there's a problem with a ground.
  9. Jun 12, 2009 at 4:59 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    If you can scan the wiring diag and post it here, I believe a lot of brother can help you out!
    Also I will not suggest you connect the green wire to high beam, I guess is the green wire is for cut off the hella 500, when u on the high beam.
    Please post the wiring diag here and talk about it.
  10. Jun 23, 2009 at 8:07 PM
    Y0TA
    Y0TA Well-Known Member
    Zac
    Central MT
    05 BLK TRD Sport 4X4
    any answers to this question yet. i tried to wire my hellas up today with the diagram and it didnt work. i didnt hook the green wire either as i really didnt see it needed.
  11. Jun 23, 2009 at 8:12 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    I ran my Hellas with the switch they provided. I just tap the switch off the radio fuse. I did this because when the ACC is on, the radio is on, hence the Hellas will be on too.
    Like what was previously stated, there maybe an issue with a good ground.
  12. Jun 25, 2009 at 7:30 PM
    sch0enne
    sch0enne Well-Known Member
    penticton British Columbia Canada
    03 Tacoma TRD
    bed lights, cobra 19 dx cb radio, flow pro muffler
    I installed mine today and had a bit of trouble. just make sure everything is grouned correctly. and you need to atleast complete the circuit with the green wire so run it from the switch right back to the battery, thats what i did. that way you can turn them on whenever you please.
  13. Jun 26, 2009 at 8:14 PM
    Y0TA
    Zac
    Central MT
    okay ill try that then. thanks
