Help With High Beam Problem (Driver Side Only)
Discussion in 'Lighting' started by BradleyJ33, Jun 29, 2010.
  1. Jun 29, 2010 at 1:29 PM
    BradleyJ33
    BradleyJ33 [OP] Geaux Tigers
    Brad
    Brandon, MS
    2010 TRD Sport 4x4 DCSB S/C'd
    TRD Supercharger with URD 2.825" Pulley, Toytec Ultimate Lift, LR UCAs, BFG All Terrain 275/70R17s on Procomp 7089 17" wheels, BAMF rock sliders, Viper 5902 alarm/remote start with smartstart, Pioneer Avic-Z110BT dvd/navi head unit, 2 Pioneer 7" monitors in headrests, 2 Rockford Fosgate Shallow-mount 10" subs pushed by RF Punch 500.2 amp, RF 5.25 components (front doors) and 5.25 full range (back doors) pushed by RF Power 400.4 amp, sound deadened, Whistler pro remote radar detector, scangauge II, debadged, Sockmonkey decals, blacked headlights with FX-R projectors, DDM Tuning HID fogs, Grillcraft upper and lower MX grill with Hella 500ffs converted to HIDs behind, AFE Stage 2 Cold Air Intake, Walbro 255 Fuel Pump upgrade, Dynomax Super Turbo muffler, Bestop Supertop, Wet Okole seat covers, Weathertech floor liners, Pop & Lock tailgate handle, Lighted 4x4 switch mod, 2 110v AC outlets in cab mod, Always at 400W mod, Maplights on with dome light mod, homelink in headliner mod, foglight
    Ok, so I just did my retrofit and everything was working great, until all the sudden while testing it out, my driver high-beam doesn't work anymore. I've check the ground, all the headlight 10A fuses in the engine compartment, all changed the connections for the solenoid, taken the bulb out to make sure the mechanism inside the projector is not stuck, etc. When I take that headlight and plug it into the connections on the passenger side, hi beams work fine, so I know it's not internal in the headlight/projector. What am I missing? Is there another fuse somewhere besides the 4 in the engine compartment for each individual hi/low beam? Please help! I'm going crazy looking for the problem! :help::goingcrazy:
  2. Jun 29, 2010 at 1:33 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    what did you retrofit in there? this will help us help you troubleshoot this issue.
    first off, take a multimeter and check to ensure you are getting something on the driver side when you turn the highs on.
  3. Jun 29, 2010 at 1:34 PM
    BradleyJ33
    Brad
    Brandon, MS
    I did the FX-R with morimoto ballasts and bulbs from the retrofit source. Used a multimeter and it's the same on both sides...wasn't sure of which settings to put it on when I checked it, but they both were the same at the connections, so I'm not sure where the problem is! Seems like if they're both reading the same, and I know the headlight/projector is good, that it should work.
  4. Jun 29, 2010 at 1:58 PM
    BradleyJ33
    Brad
    Brandon, MS
    Ok, just double checked the fuses and they're all good, again. I unplugged the H4 plug from the kit and hooked up my stock headlamp, hi and lo works perfectly. Have I ruled out everything but the relay? Does the relay even send the signal to the hi beams individually to each headlight?
