help with injector removal
Discussion in 'Performance and Tuning' started by 98_Mud_bug, Sep 5, 2010.
  1. Sep 5, 2010 at 4:41 PM
    98_Mud_bug
    98_Mud_bug [OP] 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    I've searched but i cant find a write up on removing injectors anywhere. is there a way to remove the drivers side injectors without removing the intake manifold? btw its a 98 with a 3.4
  2. Sep 5, 2010 at 4:48 PM
    98_Mud_bug
    lucedale Ms.
  3. Sep 5, 2010 at 5:36 PM
    98_Mud_bug
    lucedale Ms.
    aww c'mon people i know somebody can help me out some..
  4. Sep 5, 2010 at 5:45 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Ill try can you take a picture of the engine bay
  5. Sep 5, 2010 at 6:08 PM
    98_Mud_bug
    lucedale Ms.
    im puttin a new injector in tomorrow morning and i was just wonderin if anybody knew if i could take the injectors out without removing the intake manifold. ive tried everything else i know to do swapped coil packs, new plugs, new wires, new fuel filter, changed the oil.
  6. Sep 5, 2010 at 8:19 PM
    ktmrider
    Junk
    well I know 3.4 vs 4.0 is a big difference but given that nobody else has contributed anything I bet you probably have to, at lease you have to on the 4.0
  7. Sep 5, 2010 at 8:40 PM
    98_Mud_bug
    lucedale Ms.
    yea everything ive read says you have to remove the intake, so major job to perform in the mornin.
  8. Sep 5, 2010 at 8:42 PM
    ktmrider
    Junk
    It shouldnt be too bad, also I would tape off the inlet ports, I dropped a nut into mine and spent a good hour trying to get it back with a magnent
  9. Sep 5, 2010 at 8:46 PM
    98_Mud_bug
    lucedale Ms.
    ha ha thanks for the advice. ive only got to change one injector. its #4. bad thing is i have to change it then drive 3 hours for work.
  10. Dec 11, 2010 at 11:13 PM
    csxrailfan
    csxrailfan Active Member
    North Cackalacky
    2021 Toyota Tacoma DBL CAB TRD / GONE: 2002 Toyota Tacoma Access Cab TRD, 2011 Tundra TRD
    How did this go for you? Did you have to take the intake off? Were you getting the ole misfire code with the engine running like crap? If so I am going through the same thing now. What brand injector did you go with and where did you pick it up from? Thanks.
  11. Dec 12, 2010 at 9:24 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    The injectors mount into the manifold.
    You will have to remove the upper and lower intake connectors to access that fuel rail.
    G
  12. Dec 12, 2010 at 1:18 PM
    98_Mud_bug
    lucedale Ms.
    yea i got it done a while back. it was fairly easy.
