Help with installation.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, Oct 12, 2021.
  1. Oct 12, 2021 at 8:44 AM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    What do I need to install these? Do I need a ball joint press? Thanks.
    611067 - TACOMA/FJ/4RNR LOWER CO BRG/SPCR KIT - $68.19
    This works for all Tacoma/FJ/4Runners 2.5 Series Coilovers.
    (***easy fitment guild: Fits ALL 6 LugToyota 2.5 Series Coilovers / IFP & RR & CDCV)
  2. Oct 12, 2021 at 8:47 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
  3. Oct 12, 2021 at 8:48 AM
    jardoo
    Beirut, Lebanon
  4. Oct 12, 2021 at 8:50 AM
    5nahalf
    Erik
    Minnesota
    Good good, a bearing press would probably be the best way to install them, but im not sure since they dont list a installation instruction on their site.
    From the looks of it, your going to pull the snap rings from the stock ones, push them out, then push in the new ones and install the new snap rings.
  5. Oct 12, 2021 at 8:52 AM
    jardoo
    Beirut, Lebanon
    thanks. Think I could use a regular table vice?
  6. Oct 12, 2021 at 8:56 AM
    5nahalf
    Erik
    Minnesota
    Ive used worse in my life to press bearings in....
  7. Oct 12, 2021 at 9:02 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    It is possible to knock these in and out with the right tools. It is very important to only push by the outer race. Pushing by the inner can damage the joint. Whenever I press in bearing races I always use an Extreme Pressure Grease to help lubricate and prevent galling. I recommend using an arbor press. A drill press could even be used depending on fitment.
  8. Oct 12, 2021 at 2:43 PM
    jardoo
    Beirut, Lebanon
    Thanks. What about anti seize instead of the high pressure grease?
  9. Oct 12, 2021 at 6:04 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    The EP Grease will serve that same purpose.
  10. Oct 12, 2021 at 10:23 PM
    jardoo
    Beirut, Lebanon
    So I can use either one? Thanks.
