Help with knocking noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by themurdataco, Jul 17, 2020.
  1. Jul 17, 2020 at 5:36 AM
    themurdataco
    themurdataco [OP] Member
    MA
    3" Toytec BOSS Lift aal rear , 18" XD Addict, 285/65/18 Nitto Trail Grappler, Grill Craft MX Series Mesh
    Can someone help me narrow this down before I start ripping her apart! I’m thinking cv axle bearing? Thanks in advance!
  2. Jul 17, 2020 at 8:39 AM
    Elikk
    Elikk Well-Known Member
    Eli
    Tacoma Trd sport crew cab 2011
    any chance those are new wheels ? Sounds like a rim weight hitting the caliper or smth
  3. Jul 17, 2020 at 8:58 AM
    themurdataco
    MA
    I wish man I have about 25k on these
  4. Jul 17, 2020 at 9:13 AM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Sounds like a thin piece of metal. Brake backing plate? Did you recently take wheels off? Maybe CV boot rubbing skid plate? Its exactly once per revolution so wont be a bearing.
    themurdataco[OP] likes this.
  5. Jul 17, 2020 at 9:25 AM
    CITY TACO
    CITY TACO Well-Known Member
    Greater New Brunswick
    15 TRD Barcelona Red
    Take the wheel off and check that weight, from what I can see and hear is that it is hitting the upper arm. You should see some sort of a mark on the weight and on the upper arm.
  6. Jul 17, 2020 at 1:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Doesn’t sound like a C.V. to me.
    Take the tire off an look. Maybe something bent the backing plate.
    I’d seriously inspect that tire weight. Because it’s really easy to check?
    Sounds like something is hitting something.
    if you really want to see if it’s a C.V. put it in 4WD.
    See if the sound changes, i seriously have my doubts.
    Let us know what you find.
  7. Jul 17, 2020 at 1:34 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Jack it up and free spin the wheel while looking at in from the inside. Should be able to see what you're hitting then.
    ToyoTaco25, Hoyle and TnShooter like this.
