help with lift(5100)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fadeaduno, Oct 4, 2016.
  1. Oct 4, 2016 at 12:37 PM
    Fadeaduno
    Fadeaduno [OP] New Member
    Arod
    SoCal
    2012 trd off road
    Led pods Headstrong 5100 level kit
    so long time lurker first time poster. long story short ive had my 2012 trd off road double cab 4x4 for about six moths and just blew out a front shock. so I work at a mechanic shop and we have an account with 4 wheel parts ive decided on 5100 on all 4 wheels I would like to level it out so question is do I really need coils and the add a leaf or can I get enough lift with just the shocks. I can get ome coils (arb2885) from 4 wheel parts also but confused on the aal they cary ome (7ap12) and revtek 1.5 aal would I also need longer u bolts? thanks
  2. Oct 4, 2016 at 4:28 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome!
    You don't need either. The 5100s have adjustable clips in the front to raise your truck with the stock springs. However, ride will suffer if you raise it much, it is far better to use a longer dedicated lift coil. If you want to level it, you don't need the AAL. For level look to lift about 2" in the front. If you want to go above 2" you should get an AAL in the rear so you don't end up nose high. I've not heard of anyone running the Rancho AAL on the Tacoma, and there is likely a reason. And the OME AAL on 4wheel parts is suspiciously cheap, but also appears to be made for the aftermarket OME (not OEM) leaf pack.
    I would suggest looking at the wheelers 3-leaf progressive AAL for best ride when doing an AAL. Single leaf AAL can ride very harsh.
  3. Oct 4, 2016 at 8:39 PM
    Fadeaduno
    Arod
    SoCal
    2012 trd off road
    Cool thanks
  4. Oct 5, 2016 at 9:40 AM
    Fadeaduno
    Arod
    SoCal
    2012 trd off road
    Crashnburn80 so if I go with the wheelers aal which is a 3 pack I would just add those to my existing 3 pack leaf spring
  5. Oct 5, 2016 at 9:57 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is correct.
  6. Oct 5, 2016 at 11:18 AM
    Fadeaduno
    Arod
    SoCal
    2012 trd off road
    Cool thanks again crashnburn80
    crashnburn80 likes this.
