Help with lift and tire size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KJsTRD, Dec 9, 2022.
  1. Dec 9, 2022 at 6:46 PM
    KJsTRD
    KJsTRD [OP] Active Member
    I am just starting to do some mods on my 2021 tacoma trd off road. I want to get it more ready for off roading here in northern Canada.
    I am adding a steel bumper and a winch this weekend. I will also add eventual a roof and bed rack, rock sliders, full skid plate.
    I would like to put 285/70R16 tires on it eventually but am unsure how much of a lift I should do in the front and rear considering the extra weight I’ll be adding.
  2. Dec 9, 2022 at 6:51 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Most likely will need a cab mount chop. Lift does not dictate which tire size you can run.
  3. Dec 9, 2022 at 7:00 PM
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
  4. Dec 9, 2022 at 8:03 PM
    kas2828
    kas2828 Well-Known Member
    Austin
    Arizona
    2020 TRD Off-road 4x4 DCLB
    So many options to go with but here is a cheap and proven setup. Go with Bilstein 5100s all around. Get some type of spring upgrade probably around 700lbs in front with the weight you mentioned. Then go with an Add a leaf or full leaf pack in the back. Icon makes a good one.
    TacoTrigger16 likes this.
  5. Dec 9, 2022 at 8:07 PM
    TacoTrigger16
    You will probably need UCA’s as well.
    kas2828 likes this.
  6. Dec 9, 2022 at 8:48 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Best to run a search and browse the forums. Been asked thousands of times.
  7. Dec 9, 2022 at 9:13 PM
    KJsTRD
    I’m not concerned about price and I rather pay more for a better quality then go with something cheap. The leaf prongs and upper control arms I’m scare off. It’s the how much should I raise the from and back to accommodate the tire size and weight that I’m unsure of
  8. Dec 9, 2022 at 9:49 PM
    TacoTrigger16
