Help with lift for 2wd.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BIGDEZUL, Nov 22, 2009.
  1. Nov 22, 2009 at 6:59 AM
    BIGDEZUL
    BIGDEZUL [OP] Well-Known Member
    Baton Rouge
    6" Pro Comp, rockstars, nittos, black mods on interior, debadged, color matched chrome bumper and grille, dynamat inside doors and floor MORE TO COME
    Ok, after lots of searching and research I've narrowed it down to either the camburg spindle lift (which I still don't know much about) and AAL in the rear or the 3" toytech coil lift with AAL. As mentioned in the header i've got a 2010 2wd, OR package, i'm trying to run a 285/70/17 tire. I know that you can with the 3" lift but my question is do you guys think it's better to save up for the new spindles or just settle for the 3"?? Thanks
  2. Nov 22, 2009 at 1:32 PM
    BIGDEZUL
    Baton Rouge
  3. Nov 22, 2009 at 2:25 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    for a prerunner, spindles are definately the way to go if u want that much lift. essentially, all you do is swap out the spindles...cant get any easier than that
  4. Nov 22, 2009 at 2:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2. If your going for the larger lift and tires, the spindles are the best bet.
  5. Nov 22, 2009 at 2:45 PM
    BIGDEZUL
    Baton Rouge
    Then I need at least 3" AAL? I can leave the shocks stock right?
  6. Nov 22, 2009 at 2:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. You will need to get longer shocks.
  7. Nov 22, 2009 at 2:51 PM
    jhodge83
    SC
    17 XLT Sport
    definately larger....prolly something slong the lines of 5125's...5100's state only for 0-2" of lift in the rear
  8. Nov 22, 2009 at 2:51 PM
    BIGDEZUL
    Baton Rouge
    Damn this is adding up$$$$!! Ok, so the bilsteins in the rear then. Can you suggest a 3" AAL pack? What's this i read about grinding the calipers??
  9. Nov 22, 2009 at 2:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What Jhodge said....Your gonna need 5125's, and your gonna need to order them for the lift you will need.
  10. Nov 23, 2009 at 7:01 PM
    BIGDEZUL
    Baton Rouge
    Ok, talked to Camburg today. He said that I would need 2-2.5" of lift in the rear. Toytech has a 2.5 set online I believe. Does that replace what I have now or do I just need the 2" AAL. Also he said the spindles make your front tires stick out .75". The XD Monsters I'm getting are 4.5" backspacing. Any suggestions for the rear so it doesn't look stupid or will it be too little to notice? Sorry for all the questions, Im a noob if you haven't figured it out....
