Help with lift idea for 07 tacoma.
Discussion in 'Suspension' started by Braden, Feb 16, 2012.
  1. Feb 16, 2012 at 5:32 PM
    Braden
    Braden [OP] New Member
    Virginia
    07 Tacoma SRS LB
    K&N cold air intake 2.5" Toytech leveling kit
    Hello to the 05+ Tacoma novices out there. I am looking for some experienced knowledge out there regarding my 07 Tacoma 4dr LB 4L 4x4. I am currently running the stock 17"x7.5" alloys wrapped in 265..17 BF A/T KOs with a 3" Toytec leveling kit.
    I want to upgrade to a select 18"x9.5" (4.75" BS) Pro Comp alloy. I intend to put the same BF A/T KO tire on these wheels (275/65 or 75ish/18), so no aggressive off road tire wanted.
    My question relates to the fact that I am confident I will clear the calipers, however I am worried about rubbing inside the front wheel wells while turning. So I am looking into Toytec adjustable coil overs (Bilstein 0-3") for the front. My intention would be to stack the spacer I already have up front on top of the adjustable coil overs an adjust them so I get an extra inch or two to prevent any tire contact in the wheel wells.
    I understand that I dont want to lift too much without dropping the differential down like the common Fabtech/Pro Comp 6" lifts with stock A arms. I don't need 6" of lift and don't want to go through that installation process.
    So, to those that know, is this a wise idea to stack my 3" spacer on adjustable coil overs to get a little more room for the 18s? I would most likely end up adding a leaf in back to balance the look at some point.
    Thanks to those willing.
    Braden
  2. Feb 16, 2012 at 5:37 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    I don't think that would be a good idea!
    Welcome to TW from a fellow Virginian
  3. Feb 20, 2012 at 10:03 AM
    Braden
    Virginia
    07 Tacoma SRS LB
    You're right. Idea would be bad for the CVs. Thanks.
