"Help" with lift/leveling kit
Discussion in 'Suspension' started by phil12382, Mar 10, 2011.
  1. Mar 10, 2011 at 2:43 PM
    phil12382
    phil12382 [OP] Active Member
    Phil
    Cols,OH
    08 4x4 dbl cab trd off rd
    Bilstein 5100's all around with OME 885s in front . 265/75/16. 5k hid, Fog 3k. Anytime fog light mod. Grillecraft upper and lower. Firestone airbags. Daystar Cradles. Illuminated 4x4 switch. Scan Guage II. LR UCA.
    Got a 08 double cable trd 4x4. Wanting to run like a 285/70/16 comes close to a 33. I've seen leveling kits anywhere from 1.5 in to 3 in. Should I go with a 2in or a 2.5in in the front and be fine in the rear to run those tires? Also would I need to get a front diff drop for the 2 in or the 2.5in? Is the toytec spacers (level kit) ok to use I've also seen readylift but there another 100$ more. Any differences?
  2. Mar 12, 2011 at 7:35 AM
    phil12382
    Phil
    Cols,OH
    ?anyone
  3. Mar 12, 2011 at 7:53 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Welcome to TW. These are the most commonly asked questions on this entire site, which is why no one has responded. Please do some searching around, but I've added a few quick comments in red above.
