Help with Lift? Newbie
Discussion in 'Suspension' started by TEX357, Jan 27, 2009.
  1. Jan 27, 2009 at 1:34 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    well i am planning on getting a lift soon but i was wondering which one you all would recommend. Ive heard about spacers and about lift kits? i don't know what the difference is? I don't plan on off roading but i just want my truck to have a more higher stance, so which would you all recommend? i am just going with a 3' lift for now instead of 6 but which do you all recommend if i dont plan on going off road just street driving?:help:
  2. Jan 27, 2009 at 1:37 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Stay away from Spacer lifts.
    Your best bet would be an OME setup from . Affordable, and it rides pretty good.
  3. Jan 27, 2009 at 4:18 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    yeah what he said.i got spacer and aal before i joined this site.boy what a mistake.i went with fox 2.0 co and light racing ucas for better ride,alignment,less stress on drive line.dont do spacer.
  4. Jan 27, 2009 at 4:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you DO decide to run a spacer lift, only consider Pre load spacers, as opposed to Top Plate spacers.
  5. Jan 27, 2009 at 5:45 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    yeah...i dont think i'd have been able to run 265's w/ my 3" top plate spacer i had....the UCA was like 1/4-1/2" away from the top of the tire on my 255's
  6. Jan 27, 2009 at 6:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have seen the distance as close as 1/16" (not on my truck). I know the gap wont get closer, but too close for me none the less.
  7. Jan 27, 2009 at 7:16 PM
    NavyNate06
    NavyNate06 yeah i fix F/A-18s
    Virginia Beach, VA
    99 Tacoma SR5
    Toytec 3 inch coilovers, OME springs/shocks, Toytec shackles, rattle can paint job, lc headers,
    i don't know, if youre not going to be doing much if any offroading, a spacer lift wouldn't be that bad. i've got the Revteck 3" with thirty three inch tires on the stock rims and have had the truck four feet in the air with no problems. all for 400 bucks for the lift. and it was easy enough for a gorilla to install. your 100% best bet would be to do your research and decide whats going to be the best for you. i'm planning on going to a fabtech or something a little heavier now that i'm doing more offroading, but for a street truck, something cheap and easy would probably work fine.
  8. Jan 27, 2009 at 7:43 PM
    The_Hodge
    SC
    u got raped for $400 for a spacer lift...even w/ AAL. i hope that was including installation
  9. Jan 27, 2009 at 8:04 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    That sounds really expensive.... what all was included? Have you installed it already?
  10. Jan 28, 2009 at 5:07 PM
    NavyNate06
    Virginia Beach, VA
    99 Tacoma SR5
    i've had it installed for about a year and a half now, and the price included new shocks. i haven't had any trouble with it and it wasn't an AAL. it has blocks for the back. i wish it had been AAL to add a little strength to the rear but oh well. at the time it was the cheapest thing i could find too. of course i hadn't found this web site or really done some deep research, although it was easy to install and it only took me three days because the locking lug nuts broke on the front end and i had to drive it with the back end lifted and the front end stock to the dealer ship to have them remove the lug nuts.
  11. Jan 29, 2009 at 8:39 PM
    Chris_
    Chris_ Member
    Elizabethtown, KY
    '08 TRD Sport 4x4
    Toytec ULK, LR UCAs, Spider Trax Spacers, Stubb's HD-SKO sliders coated with Line-X, Grillecraft MX series grille
    I am very new to the Lifting realm and have a couple of questions as well if the OP doesn't mind me hyjacking his thread hah!
    I have a 2005 Tacoma 2 Wheel Drive TRD w/ locker (not sure if the TRD even comes w/o the locker). I do not plan on doing much off-roading, mostly trails for hunting and such. I am looking at the OME 885s with AAL for the rear. Budget is kind of tight so I was thinking of replacing the stock struts/shocks a couple of months down the road unless it's a bad idea to wait. I have read that new UCAs are needed but is that for the alignment or for more durability for off-road use? Trying to avoid $669 for the TC UCAs :)
    I've been reading these forums every chance I get for the past week and have gathered a lot of useful information form you gentlemen already.
    Once again, sorry for hijacking your thread Jeyet!
  12. Jan 29, 2009 at 8:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The OME 885 springs are designed to be used with the OME n140s shocks, so you should get them. You can wait on the UCA's, but your caster will be near .6*. Spec is 2.5 to 3.1*
