Help with lift options!
Discussion in 'Suspension' started by MWilliamson, Sep 3, 2009.
  1. Sep 3, 2009 at 1:59 PM
    MWilliamson
    MWilliamson [OP] Well-Known Member
    GA
    09 PreRunner SR5
    Pioneer AVIC X710BT
    I've been reading the forums and doing the searching and I think i've narrowed it down. I just want to make sure I got everything straight. BTW, I drive an 09 DC SR5 Prerunner 2WD. I'm upgrading to TRD O/R wheels for the time being.
    Option 1- Toytec Ultimate Lift Kit. From what I've read, this lift will basically require new UCAs so the truck can be aligned and possibly brake lines for the rear. Is there anything else I'm missing?
    Option 2- Lift spindles. Since I'll be running stock wheels, i'll need 1/4 inch spacers to clear the spindle correct? What about brake lines. What would be the best way to lift the rear to match the height of the front?
    Thanks guys. I've gotten a little overwhelmed!
  2. Sep 3, 2009 at 2:19 PM
    Gsquare
    Gsquare The G stands for smooth
    GG
    Lone Star State
    2018 - TRD Off Road 4x4 - Cement / Graphite - DCSB
    ReadyLIFT 3/2 Lift Kit, T-Force TRD Black Satin Spoke Wheels, OEM TRD Red/Black Resin Center Wheel Hub Covers, Toyo P285/70R17 Open Country AT's, SpiderTrax 1.25 F/R Wheel Spacers, Blackout Pkg: Tailgate Letters, Badges and Tailpipe Extension, Qi Wireless Charging, LED Bed Lights, Power Tailgate Lock, Shark Running Boards, Weathertech Floor Mats, U.S. Airforce Decal Drivers Side Rear Window, MESO Gasshole Fuel Cap Holder, OEM Trailer Hitch Cap
    I'm running the Toytec ULK with stock UCA's and brake lines with no problems. Steering wheel is straight, no vibration, no pulling, no noise.
  3. Sep 3, 2009 at 2:30 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I've got a 3" spacer up front with a rear AAL and i'm running stock UCAs. I need to get after market UCAs because my tires won't camber out correctly. Other than that everything is great! My suspension is a lil stiffer but thats to be expected...But i think the spindle lift would be sick!!! Camburg makes a nice 4" Spindle lift that looks amazing!! Thats what i'm gonna upgrade to next :thumbsup:
  4. Sep 3, 2009 at 2:33 PM
    MWilliamson
    GA
    09 PreRunner SR5
    Pioneer AVIC X710BT
    I thought about a spacer lift. I really won't be doing any off roading, just want the look. I still want a good ride though.
  5. Sep 3, 2009 at 2:41 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Well goto http://www.fatbobsgarage.com and browse through their spacer lifts. I got my true 3" lift for under $150 out the door ;) My ride is fine, its not all bumpy and annoying or anything like that. If you do get the spacer lift, don't get the diff. drop since your not a 4x4 :thumbsup: and that'll save ya some loot!
  6. Sep 3, 2009 at 4:05 PM
    MWilliamson
    GA
    09 PreRunner SR5
    Pioneer AVIC X710BT
    did you get the setup that bolts on top of the stock strut assembly so you don't have to compress/remove the coils?
  7. Sep 3, 2009 at 4:14 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    dude, how the hell did you get medically retired as a 1st LT? did the AF give you cancer or something?
  8. Sep 3, 2009 at 4:18 PM
    MWilliamson
    GA
    09 PreRunner SR5
    Pioneer AVIC X710BT
    tore every tissue and ligament in both knees. Pretty much can't do anything that I used to except walk, and I'm lucky to get a straight line!. Definitely couldn't stay in the military, medical board retired, VA benefits/care for life.
  9. Sep 4, 2009 at 7:48 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    damn dude, how did you do that? i got MEB back in January w/ 20% for a shoulder injury i got while a combat dive school. AF said i could get surgery and maybe stay in to do a desk job or take the MEB. no way was i gonna be a triple stack desk job.
  10. Sep 4, 2009 at 12:01 PM
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    Can't recommend the OME kit that Toytec sells enough! :)
    Many guys don't run aftermarket UCA...including myself. Haven't had any issues. With the Toytec coilover kit though, I can see it rubbing.
    Is it really necessary you get coilovers? If not the OME set-up is awesome and will be more than sufficient for you. Cheaper too!
    Kind Regards,
  11. Sep 4, 2009 at 5:31 PM
    MWilliamson
    GA
    09 PreRunner SR5
    Pioneer AVIC X710BT
    It's not neccessary to get CO, was just gonna get them for a faster/easier installation!
  12. Sep 5, 2009 at 11:39 AM
    r12rex
    The installation may be easier, but it's a royal pain in the arse to adjust them. I have them on my Track Subie. Turning those damn perches and getting them to the height you want sucks.
    It's probably easier to set it and forget it. Plus Coilovers need servicing every couple of years. With the OMEs you won't have to do anything to them. :)
    Kind Regards,
