Help with magnaflow
Discussion in '1st Gen. Tacomas (1995-2004)' started by bellero, Jun 20, 2014.
  1. Jun 20, 2014 at 8:28 PM
    bellero
    bellero [OP] Well-Known Member
    Wainwright, Alberta
    Tacoma 2003
    Hi guys,
    I want to replace my whole exhaust system, everything except the manifold.
    The exhaust is rusted with a few holes and I bent it while off roading.
    My question is what do I need to replace the following parts(parts number etc)
    -Magnaflow cat back exhaust system (Which one do I need)
    -Catalitic converter (Is it better to go OEM?)
    -Both O2 Sensor (I know I need OEM to avoid codes, what's the parts numbers?)
    -What else do I need?
    Truck is a 1st Gen, 4x4, extended Cab, 3.4L
    Thanks guys
  2. Jun 21, 2014 at 8:30 AM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    anybody??
  3. Jun 21, 2014 at 5:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  4. Jun 21, 2014 at 7:23 PM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    Thanks a lot man. I found the Magnaflow exhaust system parts number: 15811
    Anybody knows if I should go with Magnaflow or OEM cat converters
  5. Jun 22, 2014 at 10:11 AM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    My truck is standard 5 speed trans, the upstream sensor I need is Denso 234-9003
    thanks
  6. Jun 22, 2014 at 10:31 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    oem is better when talking cats
  7. Jun 22, 2014 at 11:01 AM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    I ordered Magnaflow stuff from the manifold down to the exhaust tip. Too late now but thanks anyway.
  8. Jun 22, 2014 at 7:32 PM
    electricjet
    electricjet Electricjet
    Tucson, AZ
    '01 Prerunner DC
    K&N, Magnaflow cats and exhaust. Electric fans.
    About a year ago I did the same thing because the computer was throwing a P420 code. Purchased the highflow cats and an exhaust system including new sensors. They were Bosh sensors and not Denso. About 8K miles after installation on comes the P420 again. Tried a pair of Denso sensors with no change. Installed a set of Bonsal cats from rock auto, reused the same Denso sensors and the light has been out for two weeks.
    I can tell the difference with the stock replacements back on instead of the highflow. The engine seems to rpm quicker and the exhaust was slightly louder.
    Also had a K&N intake as well that kept throwing a lean mixture code as well. That came off and the code went away. I was not really impressed with the shield for the K&N it allowed hot underhood air in because the engine would knock under anything but light acceleration after sitting in traffic. Original airbox cured that problem. I will get a K&N OEM style filter.
    Come to the conclusion that the 3.4 is much more sensitive to aftermarket mods than my 22RE was.
  9. Jun 22, 2014 at 7:42 PM
    electricjet
    Tucson, AZ
    '01 Prerunner DC
    The nuts holding the cat to the manifold will be rusted and might require a torch to get off. One of mine did and we torched it enough to split it thus saving the threads. Get a die at 10 x 1.25, three stainless washers, lock washers and nuts from ACE hardware. The nuts are bigger than OEM and have better clamping power.
