Help with mini d2s and xb led halo
Discussion in 'Lighting' started by XXFattyHunterXX, Jan 16, 2013.
  1. Jan 16, 2013 at 9:03 PM
    XXFattyHunterXX
    XXFattyHunterXX [OP] Well-Known Member
    Westminster, Colorado
    T4R
    So I'm about to install my retrofit kit soon and have a few questions, this will be on my 2012 Tacoma.
    1: how do you guys mount the xb led halo to the shroud? I have Apollo shroud.
    2: what is needed to be done for me to run the halo as dtrl in replacement of the turn signal?
    Thanks in advance!
    Pirhett likes this.
  2. Jan 16, 2013 at 9:22 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Don't.
    The flashing of the turn signal will destroy the CCFLs.
    Just run them to a switched power source that comes on with the ignition.
    Pirhett likes this.
  3. Jan 16, 2013 at 9:23 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    The XB Halo is led not ccfl
    Pirhett likes this.
  4. Jan 16, 2013 at 9:34 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ahh... Then it can be wired parallel with the stock 3157 lamps.
    Pirhett likes this.
  5. Jan 16, 2013 at 9:38 PM
    PLC721
    Patrick
    Chandler, Az
    Being led do you think there would be any problems?
  6. Jan 16, 2013 at 9:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    As long as they are designed to handle the heat from the projectors, should be no problems.
    The flashing won't be a problem for LEDs, nor will using them as DRLs... they'll last longer than CCFL.
  7. Jan 16, 2013 at 9:44 PM
    WYOTAC
    WYOTAC Well-Known Member
    Joel
    Santa Barbara
    06 AC TRD OffRoad Desert Sand
    Billstein 5100's, OME 884, AAL, TRD exhaust, Window Tint, color matched Satoshi grille, Hella 500's behind grill, Front Skid Plate, shovel mount in bed, illuminated 4X4 switch, Avid Offroad rock sliders, yellow sleeved fogs, toolbox mount with jerry can and bike mounts, Mini D2S Retrofit.
    Depends on what size halo you have and if it fits on the inside or the outside. I mounted my Halo's inside the Gatling gun shroud with a few dabs of JB Quick on the back of the halo ring to the sides of the shroud.
    Pirhett likes this.
  8. Jan 16, 2013 at 10:01 PM
    XXFattyHunterXX
    T4R
    Thanks for fast response guys. What I meant was I would like the halos to be on all the time as dtrl while the stock dtrl off and any use as turn signal.
    WYOTAC, I have 90mm led and wanting to mount them outside the shroud, so just have to glue it somehow?
  9. Jan 16, 2013 at 10:09 PM
    WYOTAC
    Joel
    Santa Barbara
    I think glueing would be the best bet... just be sure to use some sort of high temp stuff and be sure to let it fully cure (couple days) before you seal the headlights back up. I've heard of others actually poking small holes and tying it into place with a small fishing line though. sounded like too much work to me
    Pirhett likes this.
  10. Jan 16, 2013 at 10:19 PM
    XXFattyHunterXX
    T4R
    Yeah the instruction on TRS said to poke holes and tie but I also feel like its too much work.
    Mine is like this and I have no idea how to hide the halo wires when install. Any thoughts?
    Pirhett likes this.
  11. Jan 16, 2013 at 10:44 PM
    WYOTAC
    Joel
    Santa Barbara
    umm... I'm not entirely sure. It looks like your contacts are out on a tab. Mine were soldered at a "T" to the back of the ring. How does it sit on there if you pull the wires around the projector through the inside of the shroud?
    Pirhett likes this.
  12. Jan 17, 2013 at 9:40 AM
    XXFattyHunterXX
    T4R
    Yeah looks like I need to drill a hole to hide the wires behind the shroud, then use silicon to mount the halo, since its LED it wouldn't melt the silicon according to TRS.
  13. Feb 22, 2013 at 8:26 AM
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    Any resolution? I just got my projectors and halos yesterday and I have the same problem. I too was thinking of drilling a small hole at the bottom of the shroud, cut the wire to fit into the hole and then splice back together.
    I also want to run them as DTRL instead of my turn signals. I thought the best way to do this would be to do the stealth mode mod and use a SPDT switch in the cab to have turn signals as DTRL's or off or halos on, then tap into the keyed power for the DTRL to run a relay to power the halos, does that make sense? What was your solution?
  14. Feb 23, 2013 at 8:36 AM
    XXFattyHunterXX
    T4R
    Yeah drill a hole on the bottom of the shroud for the wire then run it through the reflector, no drilling. As to running them as dtrl, I use Quick splices (thanks to Datsik), for the dtrl, stay away fro the green wires on both side, black wire from halo go to the black and white wire(middle), red goes to yellow for driver side, and blue for passenger side.
    Pirhett likes this.
  15. Feb 23, 2013 at 3:26 PM
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    Im looking forward to seeing finished product pics.
  16. Feb 25, 2013 at 7:54 AM
    Slesse
    Kyle
    Port Coquitlam
    08 Tacoma
    Got this last night, went pretty easy.
    Does this disable your turn signal lights as DTRL or are they on together? The halos said to run the power from a relay source, does this matter?
    Lets see some pics of the final product!
  17. Feb 25, 2013 at 7:59 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx
    HOLY CRAP!
    Sara Lee pies buy one get one free?!?! :drool:
    Pirhett likes this.
  18. Feb 26, 2013 at 6:27 AM
    XXFattyHunterXX
    T4R
    It will not disable dtrl, however if your dtrl is set up as turn signal, then it will blink with your stock turn signal, so not recommended for CCFL angel eyes, LED is OK. I'll post pic of mine in a bit but moisture got in my light in snowy weather while driving so gotta redo this weekend.
  19. Feb 26, 2013 at 7:30 AM
    XXFattyHunterXX
    T4R
  20. Feb 26, 2013 at 9:42 AM
    Slesse
    Kyle
    Port Coquitlam
    08 Tacoma
    I was thinking about this last night as I want independent control of the halos and I don't necessarily was them on with the stock DTRL and I don't want them as turn signals either. Since my truck came with DTRL I was going to do the stealth mode mod, so I can manually disable them and keep them as turn signals. Then I was going to power a relay with the power wire for the headlights and hook up the halos to the 87a terminal (normally closed), that way the halos will automatically go off when my head lights come on.
