Help with my 2.4L's pinging
Discussion in '1st Gen. Tacomas (1995-2004)' started by poolman007, Jan 2, 2016.
  1. Jan 13, 2016 at 6:24 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    here's my descriptions on pings.
    Ping, take a heavy ball pin hammer and smack an anvil with it. Thats a ping to me
    Also a ping. when you're full throttle on a motorcycle and you hear a similar ping to hitting an anvil with a hammer. This is what im hoping youre talking about with your truck.
    Knocking. knock on an anvil..... it's a very muffled ping. there ya go.
    either way though.
    pinging. listen to the clicks from this engine.
    knocking
    again this is what I think of when i hear pinging and knocking.
  2. Jan 14, 2016 at 7:44 PM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    On that second one, I never would have guessed 'bad belt'. Sounded like a single valve tap to me.
  3. Jan 16, 2016 at 1:46 PM
    poolman007
    poolman007 [OP] Member
    well pinging is pinging you dont really have to hear it with your own ears, when your accelerating it sounds like you have marbles in you cylinders, I am wondering what makes you think its the maf sensor
  4. Jan 16, 2016 at 2:08 PM
    poolman007
    yes the truck has pinging good old marbles in the cylinders sound not a rod knock, not valves or lifters, belts or bearings not a rattle nothing like that.
  5. Jan 16, 2016 at 3:06 PM
    Gooch
    Orange County CA
    It was mostly TIC (tongue-in-cheek), having fun with Cali- and CodeSeven, but it did fix my pinging problem. Different engine, but there's still a possibility that it could fix it. I think it's worth a shot for $75, two screws and one connector if the OP has already tried a bunch of things.
    https://www.tacomaworld.com/threads...tane-and-hesitating-from-idle-no-load.406638/
  6. Jan 16, 2016 at 5:50 PM
    CodeSeven
    Serge.
    Coachella Valley
    yeah. his marbles came from a MAF reporting the wrong airflow, causing an ultra lean situation. lean situations in the cylinder cause higher temperatures. higher temperatures can ignite 87 octane fuel just by the cylinder wall temperature alone, without any spark.
  7. Jan 16, 2016 at 5:54 PM
    Gooch
    Orange County CA
    I lost my marbles and they ended up in my cylinders.
  8. Jan 17, 2016 at 2:26 AM
    poolman007
    sounds like good info, so you guys had pinging and a new maf sensor did the trick
  9. Jan 17, 2016 at 8:03 AM
    Gooch
    Orange County CA
    Just me. Also had hesitation.
    V6
    YMMV
