Help with my King suspension / stock shock lengh
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doidera00, Jul 2, 2015.
  1. Jul 2, 2015 at 7:23 AM
    doidera00
    doidera00 [OP] New Member
    Connecticut
    2014 Tacoma Crew Cab TRD Sport 4x4 6SPD manual
    King coilover in the front and rear shocks on the back. 18" Fuel wheels, LED light bar
    Hi how are you guys. I bought a 2014 Tacoma with King coilovers in the front and rear shock on the back. On the rear I have a 1" lift block. My issue is. The truck rides really stiff on the rear. after a while driving the truck my back actually hurts from all the stiff bouncing. my rear shock length is 24.29" ext - 15.83 collapsed. Also i just checked and i have 100psi of pressure on the shocks. is there any way to make the truck ride a little smother. I'm just about to buy a new set of rear shocks with the adjustments on it and see if that helps. Also i wanted to add a 2" maybe a 3" lift block on the back. Do i need a 10" travel shock for that? What is the oem shock dimensions and travel length? I'm not sure with the king rear shock is long enough for a 2" or 3" rear block. My truck right now when i measure is leveled, however when you look at it the front looks like it higher than the rear. so i wanted to lift the rear a little to change that.
  2. Jul 2, 2015 at 7:25 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    This section is for 3rd gen Tacomas. Post in 2nd gen for better response.
  3. Jul 2, 2015 at 7:29 AM
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    As for the shocks being stiff, just send them in to king and tell them you want them a lot softer, they will re-valve them for you. And for add a lift it depends where the shock you have now sits at ride height, so check how much shaft is showing at ride height and when the shock is fully extended. That will tell you how much droop you have. It also could be your springs too though.
  4. Jul 2, 2015 at 7:36 AM
    doidera00
    Connecticut
    thank you. I'm new to trucks. i forgot to double check what gen mine was
  5. Jul 2, 2015 at 7:40 AM
    doidera00
    Connecticut
    I have about 4.5" of travel at ride height "shock shaft showing". So I'm about in the middle of the travel length. I'm just not sure if the shock can be kind of the top of its travel length. i think that might not be good
  6. Jul 2, 2015 at 11:18 AM
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Yeah if you take 2" or 3" out of your droop to lift it you'll probably be topping out often which would be pretty annoying.
  7. Jul 2, 2015 at 7:23 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I have a 16 Tacoma and what KING Shock lengths do I need? How can I easily measure my shaft?
  8. Jul 20, 2015 at 11:48 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Hah...measure your shaft...
  9. Jul 21, 2015 at 7:07 AM
    agunday21
    agunday21 Well-Known Member
    Michael
    Flagstaff
    2015 White DCSB TRD OR 6spd MT
    •Total Chaos Uniball UCA's •2.5" King Coilovers •Deaver custom U402 leaf springs •2.5" Rear King Smoothbodies •16x8 Method Standard's •LT285/75-16 Goodyear Duratrac's •Wilco Offroad PreRunner Tiregate •Stewart's Race Works floorjack mount - mounted in bed •3 ton HF floor jack - mounted in bed •Cab Mount Chop - Relentless Fab Plate •Flattened pinch weld •BAMF Sliders (bolt on + no kickout) •Spintech 6000 muffler •Relentless Fab Bed Bars •CVT Mt. Shasta
    Take off that rear block and it will be smooth. Or go to king and get them valved at a softer rate, or get better leaf springs to achieve your desired height. I have 2.5" kings front and rear and I have no issues with stiffness but I also have Deaver springs instead of the stock springs
  10. Jul 27, 2021 at 1:13 AM
    VYPER
    VYPER Well-Known Member
    Alex
    2010 Silver Tacoma TRD
    This is my exact situation.... What could I do to combat this? Other than lifting the rear more
