Help with my King suspension / stock shock lengh
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doidera00, Jul 2, 2015.
  1. Jul 2, 2015 at 7:27 AM
    doidera00
    doidera00 [OP] New Member
    Connecticut
    2014 Tacoma Crew Cab TRD Sport 4x4 6SPD manual
    King coilover in the front and rear shocks on the back. 18" Fuel wheels, LED light bar
    Hi how are you guys. I bought a 2014 Tacoma with King coilovers in the front and rear shock on the back. On the rear I have a 1" lift block. My issue is. The truck rides really stiff on the rear. after a while driving the truck my back actually hurts from all the stiff bouncing. my rear shock length is 24.29" ext - 15.83 collapsed. Also i just checked and i have 100psi of pressure on the shocks. is there any way to make the truck ride a little smother. I'm just about to buy a new set of rear shocks with the adjustments on it and see if that helps. Also i wanted to add a 2" maybe a 3" lift block on the back. Do i need a 10" travel shock for that? What is the oem shock dimensions and travel length? I'm not sure with the king rear shock is long enough for a 2" or 3" rear block. My truck right now when i measure is leveled, however when you look at it the front looks like it higher than the rear. so i wanted to lift the rear a little to change that.
