Help with my new-to-me Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scottlippy4, May 25, 2016.
  1. May 25, 2016 at 7:52 AM
    Scottlippy4
    Scottlippy4 [OP] Well-Known Member
    Scott
    Woodstock, Ga
    05 SWB AC TRD OR V6 4x4
    Stock
    Hey everyone, I finally did it. I bit the bullet and got a 2005 speedway blue TRD OR 4x4 v6. It has 166k miles but seemed pretty clean. It's my first truck/car so this whole thing is new to me.
    Well anyways, there are a few sounds coming from the truck that I need help with. I got the truck Monday night and Tuesday night I noticed a weird squeaking sound. I can't really tell from where and I don't know what to do. Secondly, there is a rattling sound from I think the front end and it almost sounds like cans rattling. It doesn't happen when in park. It's noticeable when moving from a stop and also really bad when turning the wheel.
    Thanks everyone in advance! I really like this truck and hope I'm not getting screwed. If there's anything I need to check let me know. Probably should of asked this prior to buying the truck but I've been looking for the better part of 6 months. When I saw this one I knew I couldn't pass up and had to get it.
    Thanks again.
  2. May 25, 2016 at 7:57 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    "Squeaking sound" Is it when moving, or not? Increase with road speed or engine speed? Does it go away after a while?
    The more info you give, the more help you can get.
    "Rattling sound" might be exhaust shield somewhere on the system rattling bit. Check to see if you can narrow down where the sound comes from.
    And welcome to TW, and Tacoma Ownership! My 2006 has 135,000 and strong as ever.
  3. May 25, 2016 at 8:04 AM
    Scottlippy4
    Scott
    Woodstock, Ga
    Stock
    The squeak- it's when moving and it seems to go away when I brake. Also it sometimes doesn't squeak at all, but typicall does. It seems to increase when accelerating but not always. I drove for 45 minutes last night and it was squeaking the whole way.
    Rattle- I'm going to see if I can get someone to put it in drive and turn the wheel, then I can check it out. Hopefully they don't run me over
  4. May 25, 2016 at 8:22 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Have you checked your U-joints?
  5. May 25, 2016 at 8:32 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    My squeak was the belt idler pulleys. My rattle was the cat heat shield rotted away at the mounting stud on the floor. A little jb weld putty [​IMG]squose (if that's a word) around the shield and stud fixed the rattle. Good luck!
  6. May 25, 2016 at 8:35 AM
    Scottlippy4
    Scott
    Woodstock, Ga
    Stock
    Thanks everyone. Are there any tutorials/pictures? This stuff is foreign to me. Should I bring it to my mechanic?
  7. May 25, 2016 at 8:35 AM
    Scottlippy4
    Scott
    Woodstock, Ga
    Stock
    Also, how do I figure out what exactly is squeaking.
  8. May 25, 2016 at 8:38 AM
    Nighthawk
    Levi
    Casper Wyoming
    Process of elimination haha
  9. May 25, 2016 at 8:57 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Personally, I just started replacing idler pulleys one by one until the squeak(s) went away.
  10. May 25, 2016 at 8:59 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    If the squeak seems to go away when braking, it might be a stuck caliper rubbing slightly on the rotor, or the dust shield on the back of the brake caliper rubbing slightly as well. Also, if the brakes are worn, there is a wear indicator that will make a squeak when the pads are worn, but that usually only sounds when braking.
    If you can get it on a lift or a jack, spin the front wheels and see if you hear the squeak. That can help narrow down where it's coming from.
  11. May 25, 2016 at 11:25 AM
    Scottlippy4
    Scott
    Woodstock, Ga
    Stock
    I'm gonna try and narrow some things down and get back to you all. Thanks
  12. May 25, 2016 at 6:14 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Leaf Springs?
  13. May 25, 2016 at 6:22 PM
    Scottlippy4
    Scott
    Woodstock, Ga
    Stock
    Also, there's a squeal when releasing brakes.... Mostly after a stop. Also the rattle is not happening all the time. But is sometimes worse then others.
  14. May 25, 2016 at 6:22 PM
    Scottlippy4
    Scott
    Woodstock, Ga
    Stock
    What should I look for?
  15. May 25, 2016 at 6:24 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    How do your brake pads look. Might be time for a cbange
  16. May 25, 2016 at 8:02 PM
    Scottlippy4
    Scott
    Woodstock, Ga
    Stock
    Will check soon
  17. May 26, 2016 at 6:41 AM
    Scottlippy4
    Scott
    Woodstock, Ga
    Stock
    Is the squeal when release breaks normal?
  18. May 26, 2016 at 6:51 AM
    Scottlippy4
    Scott
    Woodstock, Ga
    Stock
    Also, braking is really bad. You have to mash the pedal all the way down to get it to start biting, and even then it's weak.
  19. May 26, 2016 at 9:49 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Well you ret brake pads have a built in wear indicator that makes a squeal when they are low. If you also have bad brake feel then you should check your pads immediately. It is not safe to not have brakes.
    It can also have to do with the rattling sound if your pads are low. When they get low enough they grind against the rotors. When you check the pads make sure to look for grooves in the rotors as well.
  20. May 26, 2016 at 9:53 AM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Sounds like your brakes (and possibly rotors) need to be changed. Flushing and replacing the brake fluid will probably help as well.
