Help with new audio system for regular cab
Discussion in 'Audio & Video' started by Silver Streak, Apr 7, 2013.
  1. Apr 7, 2013 at 7:49 PM
    Silver Streak
    Silver Streak [OP] Well-Known Member
    Westin Bull Bar
    I have a couple questions so here i go. A little info on what id like to do. -- Just a basic single din deck. 50Wx4 22w rms around about. Decent 6.5 speakers. Polk or something along those lines. Not sure if i should go for replacing tweeters too?
    1 - Which dash kit is a good one? One that actually fits like its supposed to? Dosn't rattle and such.
    2 - Do i have to get adapters for the tweeters and 6.5" speakers? not sure if they work without them.
  2. Apr 7, 2013 at 8:23 PM
    ProForce
    ProForce IG @proforce1
    Anthony
    SoCal-Ontario
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    If you are not replacing the tweeters, buy 6x9" speakers for the front that way you don't need adaptors to fit the 6.5 in there. Polk is a decent speaker for running of ahead unit without amp. Also good are Rockford fosgate 3 way 6x9's. Or even alpine type S. Type E suck IMO and type r shouldn't be run without an amp.
    Sounds like your on a good start for a basic system.
  3. Apr 7, 2013 at 10:50 PM
    eric3187
    eric3187 Well-Known Member
    sounds like you want a very basic setup. you might benefit most from just upgrading the headunit and adjusting the EQ to make stock speakers work best.
    i would definitely replace the tweeters if replacing the speakers.
