Help with new fox coilovers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mpatrick, Jul 1, 2014.
  1. Jul 1, 2014 at 11:18 AM
    mpatrick
    mpatrick [OP] Well-Known Member
    Mason
    Rancho Cucamongbruh
    2019 TRD Offroad 4x4
    Bro Dozer II
    Hey everyone, I recently got a set of fox 2.5 0"-3" lift coilovers for my 2011 tacoma. My question is do I need anything on top of the coilovers for install? I have heard that I do not need anything and that I might need some things.. Can any one confirm if I need anything else of if just the coilovers is all I need? Thanks!
  2. Jul 1, 2014 at 11:25 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Just coilovers unless you wanna put the trim pack for the taco lean
  3. Jul 1, 2014 at 11:36 AM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    Trim pack?
  4. Jul 1, 2014 at 11:39 AM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Its just an extra spacer for the driver side. 1/4 to 1/2 inch
  5. Jul 1, 2014 at 11:49 AM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    Just trying to get the 3" from the coilovers. And then maybe a leaf pack down the line. But if I get UCA's does that make it a "mid" travel kit? Or what makes it a mid travel kit
  6. Jul 1, 2014 at 12:11 PM
    aubi1414
    Justin
    Pensacola, FL
    yes mid travel is any lift that's not long travel :)
  7. Jul 1, 2014 at 1:17 PM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    Ok, sorry I'm not up to date on everything. But what would be a good front mid travel set up? cause I have the coilovers, but maybe UCA's and brake lines? Or what do you guys think?
  8. Jul 1, 2014 at 1:20 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    ok, so couple things
    you don't/won't need the trim packer. Those are to be added to set coilover assemblies that are not adjustable; since the coilovers are adjustable, you can fix the taco lean with the coil seats themselves
    you don't need anything else. Coilovers are pretty much plug and play if they're already assembled. if anything, you might want to pick up a set of spanner wrenches to adjust the coils to your liking (if you didnt already get a set)
    no, those are just "lifts"
    mid travel matches uniball control arms in front with extended travel coilovers, and an aftermarket leaf pack w/longer shocks in the rear
  9. Jul 1, 2014 at 1:31 PM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    Ok, sweet. And I have the wrench so I'm good there. But basically for a mid travel set up, which is what I'm trying to get as close to as possible, I need a Uniball UCA, lead pack and obviously new rear shocks, (which I'm already in the process of getting..
  10. Jul 1, 2014 at 1:43 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    give them a coat of clear paint before install. They will be totally rusted out in a single year if you are near the ocean.
  11. Jul 1, 2014 at 1:44 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    to gain travel up front you'll need extended travel coilovers, otherwise the uca's will just be helping with alignment rather than adding travel
  12. Jul 1, 2014 at 1:48 PM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    About an hour from the ocean so I think I'm good! And ok, I see. So are UCA's good to have with this set up though? And I'm looking at either the 0-1" or 2-3" fox remote reservoir shocks. So what would be my best rear set up?
