Help with new rims and tires!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveoct24, Sep 8, 2016.
  1. Sep 8, 2016 at 10:41 PM
    steveoct24
    steveoct24 [OP] New Member
    I am putting a 3 in lift on and was looking at new tires and rims. The rims I wanted are 18 in with a 12mm offset and 5.47" backspacing. the tires I am looking at to put on those are 285/65r18(32.6in diameter) but I am afraid of rub and really don't want to do any trimming...I know I can save some space by going down to a 275/65r18 (32.1in diameter) but those tires are much less common and don't really want to go down to a 265/65r18(31.6in) because that would cut my sidewalls down to just 6.8" when they come with 7.3" sidewalls on the stock tires. I really don't know much about the offset and backspacing truth be told...anyways if anyone has any knowledge on this they can pass my way it would be greatly appreciated
  2. Sep 8, 2016 at 10:47 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    You want 4.5" of backspacing to avoid rubbing the UCAs. And if you want a bigger tire you run the risk of rubbing. Chances are you'll only need to trim the inner plastic fender liner which you can do with a pocket knife. You may need to trim the actual fender a bit, but it's easy and it's the inside part of the fender. Can't even see it from 5' away.
    From the sounds of it, your wheels are 18x9" which means a -12mm offset to get 4.5" BS and that'll stick out more creating more rubbing and more trimming.
    steveoct24[OP] likes this.
  3. Sep 8, 2016 at 10:48 PM
    GYOAZ
    GYOAZ Well-Known Member
    Gary
    Tucson, AZ
    2015 Tacoma SR5 4X4 MGM access cab
    Billies and Eibachs, Camburg BJ UCAs, Demello hybrid sliders SOS HC rear bumper, SOS front bumper, Warn M80000, fully armored, Safari snorkel, No-slip locker, diff breather, bumper and roof mounted light bars, onboard Viair, 275/70 17 BFG ATs, and a badass sound system.
    I'm running 275/70/17 and was running them for almost a week before my 3" lift was installed. I had minimal rubbing then and zero rubbing now. I believe my wheels are a 4 inch backspacing.
  4. Sep 8, 2016 at 10:55 PM
    steveoct24
    the offset of 12mm and the BS of 5.47 are just what the website gave me for my truck when selecting the rims they are 18x9 s
