Help with noise from front end...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lodi781, Dec 30, 2016.
  1. Dec 30, 2016 at 12:05 PM
    lodi781
    lodi781 [OP] Alexander Supertramp
    shelton CT
    '16 4runner trail
    ARB by-51’s, dobinson springs, Gobi Rack, Black Oak single row LED roof bar
    Only happens in 4wd. Cracking like rocks. Pretty much what a blown CV joint might sound like, but how could it be a CV if it only happens in 4wd? Wouldn't it happen all the time? It's coming from the from right side behind the wheel. Any thoughts?
  2. Dec 30, 2016 at 7:11 PM
    Eric J
    Eric J Well-Known Member
    Ponte Vedra Beach
    2008 MGM dcsb 4x4 Trd sport debadged
    To many to name
    Dose it happen right when u turn the switch to engage 4x4?
  3. Dec 30, 2016 at 7:15 PM
    lodi781
    shelton CT
    '16 4runner trail
    No, I flip the switch, It engages, I drive 2 feet and it starts cracking. I turn right it gets bad.
  4. Dec 30, 2016 at 7:33 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    Something's with the cvs look at them and see if there torn
  5. Dec 30, 2016 at 7:34 PM
    lodi781
    shelton CT
    '16 4runner trail
    That's what I thought. A friend was saying it would do it in 2wd if it was a cv joint, but its coming bad from the right front side and there is nothing else i can think of.
  6. Dec 30, 2016 at 11:29 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    a bad cv joint is likely the problem/noise. they are quiet in 2wd because there is no torque being applied to the joint (they're free-wheeling). when the hub is engaged and the axle shaft tries to rotate the wheel the joint makes a popping/cracking noise.. if the boot is ripped open and the grease has flung out the axle needs to be replaced. they can also make noise even when the boot is intact and all the grease is still packed in..
    MO Tacoma likes this.
  7. Dec 31, 2016 at 10:28 AM
    lodi781
    shelton CT
    '16 4runner trail
    YA, I think so too. I'm ordering the part monday. Such a pain in the ass to fix though.
