Help with odd rattling sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mjwoodworks, Jul 16, 2022.
  1. Jul 16, 2022 at 1:09 PM
    Mjwoodworks
    Mjwoodworks [OP] Member
    Michael
    Central Florida
    Ford Blue 5 speed '96 Taco I4 2.4
    1996 2WD Taco 2rz-fe Manual 5-spd
    This sound occurs on startup and at rpm increase from low rpm. There are many rattles on my truck but this one did not appear until after installing new motor mounts and a transmission mount. The motor seems to shake on start a lot more than before with the new mounts installed, the motor is also shaking quite a bit when bouncing off 1,000 rpm. I would assume because the mounts are soft new rubber. On idle and on the road they are a noticeable improvement, my steering wheel still shakes a little but it's no longer noticeable unless you're really looking close at it.
    The rattle does not occur with the clutch pressed in!!!
    So other than the infamous Tacoma Tick, any ideas what's making the noise? Looking at the engine from the front of the vehicle it seems to be coming from the back of the motor above the transmission bellhouse.
    Here's two videos.
    https://www.youtube.com/watch?v=cKctv18ghLI
    https://www.youtube.com/watch?v=f3OGlslNN9s
  2. Jul 17, 2022 at 5:52 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Have you gone through the work that was just done and make sure everything’s on tight? Sometimes leaking exhaust can make noises you wouldn’t think was air.
    Check the exhaust hangers I had a shop bust a weld off putting it on a lift made a rattling noise
    had a loose pulleys make some weird noise too I’d check those.
    crazytacoman likes this.
