Help with oem fog swich
Discussion in 'Lighting' started by adamw, Mar 7, 2012.
  1. Mar 7, 2012 at 8:58 PM
    adamw
    adamw [OP] Well-Known Member
    sunnyvale, CA
    06 prerunner-> FJC 4x4 swap
    I ordered an oem fog light switch (for hellas) to go in one of the blanks next the the actual fog light switch. do I also need to get the harness that plugs into the 4 prongs in back of the switch or can I just use spade connectors for the switch?
  2. Mar 7, 2012 at 9:01 PM
    Aggiesdm
    Aggiesdm Well-Known Member
    San Antonio
    17 TRD OR 4X4
    SnugTop topper, WeatherTec mats, thats all for now
    You can just use spade connectors. Just make sure you get the right size and get ones that have an insulated jacket around the "head" so that you don't get any sort of connectivity between them. That is one of the purposes of the OEM plug...keep them isolated from one another to avoid connecting that circuit. Good luck
  3. Mar 7, 2012 at 9:10 PM
    adamw
    sunnyvale, CA
    okay thanks
