help with OME lift kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by ls1miguel, Jul 27, 2013.
  1. Jul 27, 2013 at 2:46 PM
    ls1miguel
    ls1miguel [OP] Active Member
    miguel
    Yuma,AZ
    2014 TRD Sport 4x4
    -TRD Supercharger -URD 2.8 pulley -URD 170 thermostat -URD Catless y pipe -Deatschworks fuel pump -TRD exhaust -AFE Cold air intake -Saiko Michi oil catch can -UG gauge -Eeaton LSD -Rotora 6 piston Calipers -FN 18” wheels -ICON 2.0 front and rear -Chaos UCA -OME Dakar Leaf pack -SOS Sliders -Brute forcé rear bumper -“ultimate headlight” mod
    how it going everyone its time to freshen up the suspension on my 03 tacoma.
    she has 246xxx miles, 4x4, sr5. I want to get an OME lift kit and i want to make sure i order the correct springs, leafs, shocks for my application. This is my daily driver and i also use it to carry my sport ATV, tow small trailer, carry kayaks. so what would you guys recommend i get?
    BTW i live in south carolina
    photo-8_2072f10554e7cc5738b2f2676d5aae6ea28a4595.jpgphoto-10_b925cc3ca9f96c6807f475748d1818ccc7e79ef3.jpg
  2. Jul 27, 2013 at 2:55 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Are you wanting to lift it or just replace with new parts. For a small lift you can go with 881 springs and a full Dakar leaf pack. It all depends on what you are looking for.
  3. Jul 27, 2013 at 3:00 PM
    ls1miguel
    miguel
    Yuma,AZ
    2014 TRD Sport 4x4
    I would like to lift it a couple inches. which shocks are better the nitrochargers or the bilsteins?
  4. Jul 27, 2013 at 8:32 PM
    ToyoTaco02
    Scott
    Decatur,IL
    If your going with ome get the nitrocharger shocks. I am a double cab just like you and I went with the 881 springs and the toytec 1/4" top plate spacer. I got a little over 2.5" of lift. In the rear I went with a new Dakar leaf pack. It rides pretty good.
  5. Jul 27, 2013 at 9:30 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    Well OME springs will ride best with OME shocks, they're designed to work with each other.
    For the record I have Nitrochargers and 881 w/ top plate spacer. I like the ways it rides, firm but not overly stiff.
  6. Jul 28, 2013 at 12:41 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    883 coils
    Dakar leaf pack
    Possibly the AAL
    Nitro charger shocks
  7. Jul 28, 2013 at 12:53 AM
    lil J
    lil J Well-Known Member
    Jacen
    Louisville
    99 Tacoma 4wd V6 Horizon Blue
    Old Man Emu Suspension
    As long as your not planning on adding a heavy duty front bumper all you need is the 881's and the full leaf pack which rides like a dream when loaded down. But you're only going to get about an inch in a half in lift, and you don't have to change out the front brake lines either.
  8. Jul 28, 2013 at 9:55 AM
    ls1miguel
    miguel
    Yuma,AZ
    2014 TRD Sport 4x4
    whats the difference between 881 and 883 coils?
  9. Jul 28, 2013 at 10:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    1-1.5'' with 881s and 2.5-3'' with 883s.
    883s will take more weight as they have a higher spring rate.
    but they are the same free standing height.
  10. Jul 28, 2013 at 11:44 AM
    ToyoTaco02
    Scott
    Decatur,IL
    Agree and disagree, it also depends on whether you are prerunner or 4x4 and v6 or 4 cylinder.
    I'm at a little over 2.5" with 881 and 1/4" top plate spacers. The 881 coils gave me just over 2" of lift.
  11. Jul 28, 2013 at 12:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    OP is a double cab auto..there for a V6 and is also 4x4 as said in the OP
    with a v6 and 4wd, 881s only give 1.5'' at most after they settle.
    also will depend on your driving.
  12. Jul 28, 2013 at 12:22 PM
    02goldie
    02goldie Well-Known Member
    Brock
    Lenoir, NC
    2016 Sport DCSB 4x4
    OME lift, spidertrax, 285 duratracs
    OME 881, Dakars, Bilstein 5100s. but i am biased....lol
    i also threw a set of helper springs on mine to carry my 4wheeler (kodiak 450) and does just fine. they only install on the rear of the leafs, i dont have the heavy duty helpers
  13. Jul 28, 2013 at 1:47 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    Granted I have an extra cab, but my truck is a V6 4x4 with 881 and 10mm top plate spacer and I have over 2.5" of lift. They do settle, but not as much as you are leading them to believe.
  14. Jul 28, 2013 at 4:52 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    This. Except the AAL should be a definite addition. That setup will do just what you need and give a great ride.
  15. Jul 28, 2013 at 5:48 PM
    Madjik_Man
    Colorado Front Range
    883s even if he's not adding weight in the front like a bumper or winch?
  16. Jul 28, 2013 at 5:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    For 2.5" of lift or more yes.
  17. Jul 28, 2013 at 10:56 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    That's what I'm running. Love it. It is a stiff ride but with a couple hundred pounds in the bed and/or towing a trailer, it rides awesome. Great offroad as well. My CVs are steep but better than most I see on here.
    And as box rocket said, get the AAL if you plan on towing a trailer with any sort of gear in the bed at the same time. It helps a lot. Check my build thread for some pics. Keep in mind it has settled a lot since I installed the suspension.
