Help with ordering wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98fourbangertaco, Jan 10, 2011.
  1. Jan 10, 2011 at 7:01 AM
    98fourbangertaco
    98fourbangertaco [OP] Well-Known Member
    Taylorsville, NC
    98 toyota tacoma, 4wd, SR5, 2.7L, 5-speed
    daystar 2.5in suspension lift kit, detroit truetrac in rear, custom transfer case skidplate, deckplate mod, green high-performance drop in filter, Huskyliner floor mats, 31x10.50 wild country radial mtx tires, yakima roof rack, load warrior basket, stubbs welding rock sliders, arb front bumper with warn 9,000lb winch and procomp black series 100w offroad lights, trail-gear rear bumper, borla exhaust, blacked out factory wheels, shovel mounted on roof rack, de-mudflaped
    i am ordering a set of 15x7 black steelies for my taco and i have a daystar 2.5in spacer lift in the front with 31x10.50s, next time i buy tires i want 32x11.50s, would i be fine to still order the 15x7 wheels with factory backspacing and fit the 32x11.50 later on down the road? Any help would be greatly appreciated, thanks in advance
  2. Jan 10, 2011 at 7:06 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    I would recommend at least a 8" wide rim for a 11.5" wide tire, and no more than a 9" wide rim. As far as backspacing goes if you get an 8" wide rim i would get factory bs, but if you get a 9" wide rim I would go like 4" bs(the tire will stick out a little further with 9" rim 4" bs).
  3. Jan 10, 2011 at 7:16 AM
    98fourbangertaco
    Taylorsville, NC
    yea im sure the 8in would work with 11.50s with factory backspacing but im really wanting 15x7s if at all possible cause i want to keep the tires under the fender flares as much as possibe
  4. Jan 10, 2011 at 7:44 AM
    goomba
    Josh
    San Antonio Fl
    Keeping the 11.5" wide tires under the fender flare is ganna be cutting it close. The closest I would feel safe doing is 8" wide rim with 4" bs.
    Ok to figure out how close you can get you need to get the width of the rim(i think it is 7" wide). Get the width of the tire(10.5" wide), and the distance frome the uca(1"). ok, now you subtract the 10.5-11.5=1.5 (tire with now to next tire with) devide by 2 you get an extra .75 inches (outwards and inwards) on each side of or your rim. Then from 7" to 8 inch rim it will stick out an extra .5 " outward. With a 3.75 bs to a 4" bs you will be sucked in .25". Now you do math to figure out the rest.
    Ok, This is ganna be fun.
    You get .5" outwards going to a 7" wide rim to a 8" wide rim. You get .75" gain on both(in and out) sides of the tire to go from a 10.5" wide tire to a 11.5" wide tire. You get .25 " in from going to 3.75" bs to a 4" bs. Now .5(out)+.75(out) = a total of 1.25" outwards. . .25"(the bs of rim) in - 1.25 out = a 1" futher out(just to see how much further your tire will stick out). Now I do not know if you will hit the uca or not because the tire is still going in about an inch. For total inwards motion of the tire .25(in)+.75(in) = a total of 1" inwards.
  5. Jan 10, 2011 at 7:53 AM
    goomba
    Josh
    San Antonio Fl
    Don't mean to sound like a nerd... :pccoffee: But now my brain feels like it is getting smashed:redxfall:
  6. Jan 10, 2011 at 10:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Back in the day (ha), I had a '98 xc with a 2.5" spacer lift, much like yours. I ran 32x11.5-15 on the stock 15x7 alloys with absolutely no problems.
    Go for it Man! If you get steelies with close to stock BS you should be fine.
  7. Jan 10, 2011 at 11:34 PM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    last time I checked going from a 10.5" to a 11.5" tyre is a gain of 1", not 1.5"
  8. Jan 11, 2011 at 6:36 AM
    goomba
    Josh
    San Antonio Fl
    ^^ Knew I missed something.
  9. Jan 11, 2011 at 6:53 AM
    98fourbangertaco
    Taylorsville, NC
    thanks guys, im gonna order some steelies the sames bs and size as my factory wheels and go with it because im gonna wear my 31s out first, i was just thinkin ahead to the next time i buy tires
  10. Jan 11, 2011 at 11:43 AM
    cab4you26
    cab4you26 Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    If you're ordering 15x8 steel wheels (black?) then order them from me! Mine are from wheelers they are the B's with 4in. B/S. I had them on my truck a month and took them off. It'd be cheaper since you'd be getting them from VA and not Oregon. That's ONLY if those are the wheels you want.
