Help with piston ring replacement
Discussion in 'Technical Chat' started by Benwaah, Nov 5, 2016.
  1. Nov 5, 2016 at 6:31 AM
    Benwaah
    Benwaah [OP] Member
    Gunnison, Colorado
    97 2.7L 5-speed 4wd
    Is there a guide or manual on how to replace piston rings on a 2.7? I have searched and searched with no luck..
    Any help is appreciated
  2. Nov 5, 2016 at 7:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just how did you arrive to the point of installing rings
    pretty straight forward
    remove the old ones install the new ones
    I hope you have the pistons out
    all the measurements have been done not that your trying to install old pistons in egg shaped cylinders
    jmaack likes this.
  3. Nov 5, 2016 at 7:31 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    It will be in the factory service manual. Or an aftermarket service manual will also have it. Major job. If my rings were shot, I'd replace the whole motor or do a total rebuild.
  4. Nov 5, 2016 at 7:53 AM
    Benwaah
    Benwaah [OP] Member
    Gunnison, Colorado
    97 2.7L 5-speed 4wd
    Right, well my situation is I bought a 97 with 248k on the clock with a blown head gasket. Just dumped $1,000 in parts (new cylinder head, head bolts, timing chains and sprockets, water pump, plugs, wires, fuel filter, belts, gaskets, oil, etc) and it was brought to my attention that I may want to replace piston rings also.
    So now I'm thinking of pulling the engine and doing just that.. I was hoping to find an online manual or guide to aid me in my journey. Buying a new engine us not in the budget and I feel it's a bit unnecessary, so I'm doing the work in my garage..
    Do you know of any online resources?
  5. Nov 5, 2016 at 8:07 AM
    Clearwater Bill
    Billy
    Largo Florida
    You want to replace rings because it was 'suggested'? Based on what?
    Once you break open the bottom end its going to take more than rings to properly reassemble.
  6. Nov 5, 2016 at 8:16 AM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    I have rebuilt a bunch of toyota 4cyl and v6 motors. If you are interested in saving money you need to buy a used lower mileage motor and just swap your new parts onto it, leaving the rings alone. If you want to do it right then you need to send that block as well as new pistons and the crank to a machine shop. You can install them for your own education, but they need to inspect, grind and fit them.
    If you decide to try and rering a high mileage motor without cleaning up the bores you are going to have a hard time. At least do some reasearch on what material rings are available and which you feel comfortable using as they have different characteristics.
    And yes each ring gap is supposed to be measured, ground, and then placed in a specific range on the piston, that limits blowby, oil consumption, and low pressures. Depending on the rings, the manufacturer might request different gap placement and end gap measurements than Toyota. Go with the manufacturer settings in that case.
    Benwaah[OP] likes this.
  7. Nov 5, 2016 at 8:20 AM
    Benwaah
    Benwaah [OP] Member
    Gunnison, Colorado
    97 2.7L 5-speed 4wd
    Thank you for this information
  8. Nov 5, 2016 at 8:29 AM
    Pickeledpigsfeet
    Foothills, CA
    Here is the ring gap orientation
  9. Nov 5, 2016 at 8:34 AM
    Pickeledpigsfeet
    Foothills, CA
    And you will easily be able to afford a used running motor for the price of the machine shop. Here in Ca it is usually between $500-$1000 just for a simple over bore and checks for damage and flatness at trustworthy shops.
  10. Nov 5, 2016 at 8:42 AM
    Benwaah
    Benwaah [OP] Member
    Gunnison, Colorado
    97 2.7L 5-speed 4wd
    Great, I'll keep my eyes out for one. Unfortunately this is my only vehicle now so I'll install all my parts and start looking for a low mileage 2.7 to swap them to
  11. Nov 5, 2016 at 8:45 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I can think of a few people that scored the crank so bad installing pistons that needed to be replaced
    Interesting how other people can spend your money .
    I guess it is good it was not suggested you sell your truck for scrap would you have done that??
  12. Nov 5, 2016 at 9:06 AM
    Pickeledpigsfeet
    Foothills, CA
    That is what i would do. If it is still together you can do a leakdown test and see what condition the rings are in.
  13. Nov 5, 2016 at 9:20 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I've only done one rebuild, and it was on an old 22R toyota 4-banger. I was able to replace the pistons without pulling the motor. I did have to remove the oil pan to disconnect the push rods from the crank. However, on yours, you may have to remove the front diff, to make room to remove the oil pan. More work.
    The whole project took me about 2 weeks of evenings and weekends, but I had a backup vehicle to drive. :D
