Help with popping noise while turning steering wheel....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ranger724, Sep 1, 2025.
  1. Sep 1, 2025 at 9:31 AM
    Ranger724
    Ranger724 [OP] Member
    2022 TRD Off-Road. 41,000 miles, stock suspension.
    Noticed a dull popping noise while turning the wheel at slow speed or starting from a stopped position. Seemed to be from under the engine skid (stock Toyota engine skid not RCI). Took off skid.
    Unable to replicate the noise with front wheels off the ground, with either the engine running or stopped and just turning the steering wheel.
    Lowered back to the ground and was able to replicate the noise again simply by turning the steering wheel left/right.
    Everything suspension wise appears tight and in good order. No weird noise from the PS rack with wheels on or off the ground.
    Video link below.
    Thank you for the help,
    https://youtube.com/shorts/brAZCpokJKg?feature=share
  2. Sep 1, 2025 at 10:38 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    Sway bar links, they make a lot of noise when they fail. Check for easy movement and crunchy rotation.
    wilcam47 likes this.
  3. Sep 2, 2025 at 1:25 AM
    Ranger724
    Thank you, they appear to be tight.
  4. Sep 2, 2025 at 1:32 AM
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
    Mine does the same thing, so I’m hoping for an answer to appear. Thank you.
