Help with power steering
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buffco, Feb 27, 2014.
  1. Feb 27, 2014 at 3:58 PM
    Buffco
    Buffco [OP] Well-Known Member
    99 Toyota Tacoma.
    Took off the reservoir because the pump started whining. Common problem for Taco's, the reservoir had an extremely fine screen in it and once it's clogged with buildup, it starves the motor.
    Drained it, flushed it, no problems. Now here is the issue: I cycled the wheels back and forth dozens of times, lock to lock, trying to purge the system. Once I started the engine, the wheels are HARD to turn, just as if there was no power steering. The fluid still wants to bubble up and out the reservoir even with the cap on.... And the pump whines constantly now.
    What did I do wrong? Besides not letting a pro service it..
  2. Feb 28, 2014 at 7:01 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    It sounds like you've got air in your ps pump to me.
  3. Feb 28, 2014 at 8:13 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You might have made it worse. How do you know that the screen/filter is any cleaner? Its not visible to the eye.
  4. Feb 28, 2014 at 9:05 AM
    Buffco
    Because I can see through the screen now. It most certainly is visible if you take the reservoir off. It was called with black gunk. No light was even coming through the bottom. Now it is.
  5. Feb 28, 2014 at 1:12 PM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    You most likely have a lot of air in the system. My guess is your fluid looks whitish and milky from all the bubbles yes? Easiest way to remove the bubbles is lift the truck up, so that both wheels are off the ground. Remove the ps fluid cap and cycle the wheels back and forth while filling the reservoir. (This'll require a second person of course) you can also increase the rpm to get the pump flowing more fluid. You'll be able to see down inside the reservoir. Just wait it out....they'll disappear eventually. Mine took about 15 minutes before the pump stopped fussing and the bubbles disappeared.
    Hope this helps ya!!
