help with preload spacer
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotaboy, Mar 22, 2010.
  1. Mar 22, 2010 at 12:09 AM
    yotaboy
    yotaboy [OP] Member
    kyle
    daytona beach
    tacoma 4x4 200,000 miles running like a champ
    4:56 gears front and rear d-locker rear ,5 1/2 inch lift,k/n intake magnaflow exhaust,pacesetter header,custom rear bumper,brush guard in the front,aftermarket head lights and tail lights,hid lights,billet grill,
    im not sure about these spacers just the 6 inch lift kits,but how thick or inches can i use for a preload spacer,dont wanna put any on top that will cause the uca`s to drop closer to the coils so any obama ideas.thanks
  2. Mar 22, 2010 at 12:15 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    :confused: Not exactly sure what you're asking, but knowing what lift you already have would be helpful....
  3. Mar 22, 2010 at 12:20 AM
    yotaboy
    yotaboy [OP] Member
    kyle
    daytona beach
    i bought this 1997 p.o.s for a woods truck my trucks got the 6 inch lift kit,but i need to know how many inches can i use for a perload spacer so i can slap these boggers on this beast
  4. Mar 22, 2010 at 12:23 AM
    RelentlessFab
    Eric
    what kind of lift? 6" suspension drop bracket? or is it like a combination of body and suspension?
    If its a 6" drop bracket lift like a fabtech or something then you can probably go with about 2" additional before too much CV issues arise.
  5. Mar 22, 2010 at 12:42 AM
    yotaboy
    yotaboy [OP] Member
    kyle
    daytona beach
    no thats on my other trucks i got the real lift for im talking about this junk box i just bought for a woods/hunting truck theres a limit for preload spacers i got these spacers here that measure out at 2 1/2 thats preloading the spring alot i dont know what preload spacers are in measurements
  6. Mar 22, 2010 at 4:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If the spacer is 1" thick, that'll give you 2" of lift.
    A rule of thumb for 4WD trucks is not to exceed 2.5" of lift using preload spacers ( 1.25" spacer thickness).
    It all depends on your current setup - and in a nutshell - you need to watch your axle shaft/CV angles.
  7. Mar 22, 2010 at 6:57 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok for max lift......6 inch lift...3 inch body lift (or custom make a larger body lift) 3 inch spacer lift total of 12 inches of lift up front unless you custom make a larger body lift). as for the rear end get creative. shackles blocks AAL.
    good luck :(
