Help with Pro Comp wheel vibrations
Discussion in 'Wheels & Tires' started by jdubber, Nov 6, 2013.
  1. Nov 6, 2013 at 9:22 AM
    jdubber
    jdubber [OP] Well-Known Member
    So Cal
    Silver 2013 OR DC
    Hi- This is my first thread and need help. I have a 2013 double cab Prerunner and put Bilstein 5100's all around to level the truck. I set the front at 1.75 and got some Pro Comp 7032 flat black wheels with 275/70/17 BFG's. Looks good but I have had it to ORW 3 times to try to fix a vibration in the wheel at higher speeds. They re-balanced and even checked the alignment and it didn't fix it. I heard about hub centric rings and demanded they put them on (108mm to 110mm ring) and it seems better but still exists. Any thoughts??? I'm at a loss.
  2. Nov 6, 2013 at 9:26 AM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    Wheel bearing?
  3. Nov 6, 2013 at 9:30 AM
    jdubber
    So Cal
    Silver 2013 OR DC
    The truck only has 2600 miles, do you think it still could be a bearing? It was fine with the stock wheels...
  4. Nov 6, 2013 at 9:56 AM
    ST3VE
    MD --> SC
    Shouldn't be a bearing with that many miles. Weird that it would be the rims though. The bigger tires might have something to do with it though. Either your not use to bigger tires or they can't get them balanced correctly. I have 285/75r16 Mickey Thomson MTZ's. Where I am from they have a balance setup called "road force" balancing. Usually balanced them perfect. It puts actual pressure on the tires while balancing. Maybe find out someone that has that?
  5. Nov 6, 2013 at 10:01 AM
    jdubber
    So Cal
    Silver 2013 OR DC
    I called pro comp and they said I should try doing the lugs by hand vs. the impact that may have been used. I may try the roadforce as well...I called a guy and he would do it for $20 per wheel, not sure if that's reasonable.
  6. Nov 6, 2013 at 11:54 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Make sure you tighten in a star pattern. I had a set of Pro Comps on my old truck and did not have any issues without hub rings.
  7. Nov 6, 2013 at 11:58 AM
    tractng
    tractng Well-Known Member
    I just recently put the new rims on and had the vibration. Try the star pattern when tightening the lugs. Make sure you hand tight them enough while the wheels are off the ground.
  8. Nov 6, 2013 at 1:05 PM
    jdubber
    So Cal
    Silver 2013 OR DC
    Thanks- will try hand tightening them tonight. Should I go with 85 ft/pounds?
  9. Nov 6, 2013 at 1:15 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
  10. Nov 6, 2013 at 1:28 PM
    ltsr
    ltsr Well-Known Member
    Bay Area, CA
    2013 TRD O/R 4x4 6MT 4.0L
    The pro comp 7032s have a weird shape inside the wheel that throws off most technicians when balancing the wheel. Have them measure from the inside spoke to the outer edge of the wheel. You know how I know this? I had the same issue with my 7032s in 16x8 last week. I am also using hub centric rings (108-106 in my case). My truck only has 18k miles. No vibration prior to installing the wheels. Hope that helps you track it down.
  11. Nov 6, 2013 at 9:56 PM
    jdubber
    So Cal
    Silver 2013 OR DC
    Thanks Itsr! Did you end up fixing the issue and did you have to pay for the road force? So many techs are measuring from the wrong spot causing them to put weights in the wrong place? wow...great tip thanks.
  12. Nov 7, 2013 at 1:01 AM
    ltsr
    Bay Area, CA
    The issue is fixed. Instead of the younger technicians, the manager did the balancing when I came back. I watched him balance the wheel with 1/2 less weights than what the previous tech used. I did not road force balance, though I did think about it as an option if this didn't work.
    If you look inside the wheel, right before the spoke the angle changes. Not sure how to explain it. All I know is that my problem is fixed. I'm also using these lug nuts:
    http://www.amazon.com/gp/product/B0040ULXY8/ref=oh_details_o05_s00_i00?ie=UTF8&psc=1
  13. Nov 7, 2013 at 5:26 AM
    Grieby54
    Grieby54 Horsebit
    Sam
    Castle Rock, CO
    '13 TRD Off Road 4x4 DCSB MGM JBL/Entune/Nav
    WeatherTech Digital Liners, ImMrYo rear view mirror bracket, color matched grille, Tacoma door sill protectors, OEM hood protector, clear bra, tint, OEM roof rack, trimmed front mud flaps to match rear clearance, debadged, color matched grille, Plasti Dipped front Toyota emblem, OME 884X coils with trim packer on driver's side, OME Nitro Sport 9000 shocks, Deaver/ToyTec AAL with OME N182 shocks, 265/75/16 Duratracs, ProComp 7032 16" wheels
    Where are you guys getting your hub centric rings from? I've had the same issues with mine. I get a small steering wheel shake at about 60 mph that I wouldn't mind getting rid of...
  14. Nov 7, 2013 at 10:05 AM
    jdubber
    So Cal
    Silver 2013 OR DC
    Thanks for all of the advice. I have the extended lugs as well...not sure the brand but the shop that installed said I needed them. I bought the hub centric rings on Amazon...they are made by Gorilla. http://www.amazon.com/Gorilla-Automotive-108-106-1-Centric-106-1mm/dp/B0032HQJ7G
    I think I am going to replace with the new rings I ordered on all 4 corners, re-torque lugs by hand and see how it feels...if I still have the problem I may just go the road force option. I found a shop that will do it for $20 per wheel.
    Thanks Itsr, I wish I could explain to these guys how to measure the wheel but I think the shop was already bothered by me pressing the issue. Do you think the road force will have the same result as a good experienced tech on the regular machine?
  15. Nov 7, 2013 at 10:43 AM
    Grieby54
    Grieby54 Horsebit
    Sam
    Castle Rock, CO
    Are you guys seeing good results from the rings?
  16. Nov 7, 2013 at 11:21 AM
    jdubber
    So Cal
    Silver 2013 OR DC
    Yes- when I went to the shop last time they re-balanced and checked alignment and then I forced them to put the rings on the front and it did make a difference. The vibration really happens only on certain types of road now...meaning I can drive on certain parts of the freeway smoothly but other parts still have the minor shake. I don't think you can loose for $12 to give it a try.
  17. Nov 7, 2013 at 12:21 PM
    tractng
  18. Nov 8, 2013 at 9:05 AM
    ltsr
    Bay Area, CA
    Since we have the same size wheels, this is what i'm using:
    http://www.amazon.com/gp/product/B0032HQJ7G/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1
    I would go back and have them re-do it again. You paid to get it done correctly. If they can't get it right, ask for a full refund until they get it right. Road force balance will probably fix it since those guys will get the balancing correctly but you should NOT have to fork out another $80+ and more of your time to fix the original shop's mistake or lack of knowing how to balance properly.
  19. Nov 11, 2013 at 12:32 PM
    jdubber
    So Cal
    Silver 2013 OR DC
    I have fixed the problem. I went to a local wheel and tire shop that had the road force balancer and found the front two tires were out of balance and one of the back wheels had way too much weight. So I had them road forced for $100 and had the hub centric rings added in the back as well and it feels like stock! I took the bill to ORW (the offroad shop that installed them) and they gave me a $100 refund. Learned they were balancing lug centric wheels only using the cone...not the hub adapter. What a joke...the manager wouldn't even look at me, I would be embarrassed as well. Thanks everyone for the advice!
  20. Nov 11, 2013 at 1:06 PM
    ST3VE
    MD --> SC
    :cool: :thumbsup:
