HELP WITH PROJECTORS!!!
Discussion in 'Lighting' started by YoungGunz23, Apr 19, 2012.
  1. Apr 19, 2012 at 1:21 PM
    YoungGunz23
    YoungGunz23 [OP] Well-Known Member
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    3" fabtech lift 33" federals
    Im wanting to get the retrofit projectors for my taco but i have no idea what kind to get or anything. Any suggestions? Feel free to give your input and upload pics. Thanks!
  2. Apr 19, 2012 at 1:24 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    TheRetrofitSource.com Either their Morimoto Mini kit or their FX-R kits are both pretty sweet. The FX-R is a better projector but the install is more involved also.
  3. Apr 19, 2012 at 1:25 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Visit TRS www.theretrofitsource.com
    Depends on what you're after.
    If you want something that's plug and play, they offer that.
    If you want something that will give you the ultimate light output with moderate modifications to your truck, they offer that too. Prices range anywhere from 200-450 for everything you need. I went with their best kit, called FX-R stage IV kit. It's legit. Highly recommend it if you don't mind cutting your headlights a bit.
    Edit: beat me to it. What he said.
  4. Apr 19, 2012 at 1:29 PM
    sofiasdad11
    sofiasdad11 Reads more than posts
    Near the Windy City, but in the country
    2011 BLACK 4X4 DCLB TRD SPORT
    Flux capacitor (2nd gen version), toytec ultimate liftkit, amp research powersteps, custom katzkin heated leather incl. console cover, retraxpro retractable bed cover, earnhardt jr. cannons@18x9(summer),ballistic jesters@18x9 (winter),285/60/18 nitto grapplers, bodymatched bushwackers, the original Homertaco full satoshi " raptor" grill, viper 5704 remote/smart-start/alarm w/viper cellulor app, ravelco anti-theft device, ipcw tails, redline hoodstruts, oem roof rack, led maps/dome, backup light mod, swingcase storage box, jl audio stealthbox and amps,focal drivers,alpine carplay unit, pop&lock premium handle, seatbelt chime disabled, tailgate hoseclamp mod, rich evans caliper covers, weathertech digitalfit mats, flyzeye V2W,oem bedmat, salex console organizer,speeddawg shiftknob
  5. Apr 19, 2012 at 1:31 PM
    YoungGunz23
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    what harness do u need?
  6. Apr 19, 2012 at 1:32 PM
    YoungGunz23
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    thanks guys for the input
  7. Apr 19, 2012 at 1:36 PM
    Pugga
    Massachusetts
    F-150 Mod
    You'll want this harness:
    High & low beam headlamp
    9003/HB2/H4
    Also, any 'plug and play' kit won't have projectors. Plug and play kits are simply throwing HID's into your stock reflector housing. The Morimoto and FX-R kits require retrofitting a projector into your stock headlight housing.
  8. Apr 19, 2012 at 1:40 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2.
  9. Apr 19, 2012 at 1:40 PM
    benbacher
    Anchorage, AK
    True, but I don't believe you have to cut anything with the morimoto's do you? I thought they fit in the existing bulb opening.
  10. Apr 19, 2012 at 1:42 PM
    Pugga
    Massachusetts
    F-150 Mod
    You still need to open up the headlight to get them installed though. There's no cutting involved since they install with a lock nut but not what I'd consider plug and play.
  11. Apr 19, 2012 at 1:44 PM
    YoungGunz23
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    thanks guys
  12. Apr 19, 2012 at 1:44 PM
    YoungGunz23
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    do you have the x2's?
  13. Apr 19, 2012 at 2:21 PM
    benbacher
    Anchorage, AK
    lol, x2 means Times two, or "I second that"
    and good call pugga, you do still have to open them up. You right. But you're going to do that with any projectors, so as far as ease of install goes, those ones are your best bet.
  14. Apr 19, 2012 at 2:23 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    morimoto mini H1's are the best projectors you can get that don't require cutting the headlight assembly. FX-R's are the best you can get with modifications
  15. Apr 20, 2012 at 6:34 AM
    Pugga
    Massachusetts
    F-150 Mod
    FX-Rs are the best readily available projector you can get with slight modification of the headlight assembly.
    LS460 projectors are better yet but require some pretty extensive modifications to make them fit and they're expensive to buy. S2000 projectors have a ridiculously wide low beam pattern but you lose your high beams.
