help with radiator coolant change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steve103, Jun 18, 2011.
  1. Jun 18, 2011 at 2:37 PM
    steve103
    steve103 [OP] Well-Known Member
    steve
    santa cruz ca
    07 taco
    arb bumper,bilstein shocks,886 ome springs,ar mojove rims,2optima batteries,custom electrial.on board air,cb,14gal frontrunner water tank,frontrunner roofrack
    so change the coolant simple thing one would think. i have never change dthe coolant in this 07 tacoma. remove cap,put on drain hose,open drainNOTHING COMES OUT. HOW COME. THANKS.
  2. Jun 18, 2011 at 3:49 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    Possible sediment lodged in the drain petcock? That happened on my '77 pickup with the 20R with the iron block. Is there any part of the cooling system on the new trucks that can rust anymore?
  3. Jun 19, 2011 at 10:07 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    any vehicle i ever had i always remove the bottom radiator hose at the radiator to dump the coolant. i then just push it back on and fill with water run for 3 minutes and pull off again, repeat about 4 times then tighten it back up and add coolant.
  4. Jun 19, 2011 at 10:20 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    there is a pet-cock on the bottom of the rad.....
