Help with Real Diff Lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MacAtk, Jul 9, 2019.
  1. Jul 9, 2019 at 1:59 AM
    MacAtk
    MacAtk [OP] New Member
    Uriel
    2011 White Tacoma TX Pro
    None
    I just bought an 11 Tacoma TX pro and I don’t know how to engage the rear lock differential. Any help would be greatly appreciated. Has no mods. It’s still stock
  2. Jul 9, 2019 at 2:58 AM
    DrFunker
    DrFunker Well-Known Member
    Welcome to TW.:wave:
    You may want to change your thread title to:
    I don’t know how to engage the rear lock diff.
    You'll more than likely get more responses.
    and...
    Help threads are usually reserved for emergencies.
    To edit:
    Upper right corner of the thread:
    :hattip:
    Tullie D likes this.
  3. Jul 9, 2019 at 3:36 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Must be in 4 low first to engage (only place it works) - push button and you should hear a clunk in the rear, if not put back in Drive if you just engaged 4 low from Neutral and move the steering wheel from side to side as you let your foot off the brake - that will allow the splines to line up in the axles with the locker. If all electronics are OK it should work and light comes on fully (not blinking)
    DrFunker likes this.
