Help with rear brake drums
Discussion in 'Technical Chat' started by Warren Thompson, Sep 18, 2009.
  1. Sep 18, 2009 at 7:47 AM
    Warren Thompson
    Warren Thompson [OP] GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    I have my '06 on jack stands doing the Cheap Traction Bar mod. I also want to check my rear brake pads (okay, I want to paint them black too), but can not get the drums off. Yes, the emerg. brake is off. Is there a trick to this?? They should just slide off, no.:confused:
    Any help would be appreciated.;)
  2. Sep 18, 2009 at 8:00 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    They should slide off, but rust & dirt will often hold them in place.
    Spray penetrating lubricant (like PB blaster) at the base of each lug. Give it some time to penetrate. Then - take a hammer and tap the areas inbetween the lugs (on the flat surface). You can tap harder but don't go crazy.
    You can also take a mallet and tap the outside edges (fairly lightly).
    Use more penetrating lube and be patient.
  3. Sep 18, 2009 at 8:35 AM
    Warren Thompson
    Warren
    Elko, Nevada
    Thanks Janster, I have had penetrating fluid on them for about half hour, still one with the axle. You have the patience thing correct!!!!
    Breath, remember to breath!!!
  4. Sep 18, 2009 at 8:38 AM
    kxhansen
    kxhansen Well-Known Member
    Ken
    Staten Island, NY
    09 Tacoma Dbl Cab SR5 6spd Silver
    WeatherTech window deflectors WeatherTech floor liners (front) and mats (rear) Alpine 9886 Pop n Lock 5300 Fold a Cover G4 GT Covers seat covers
    I had a similar problem with my 1980 Corolla........Tried the penatrating fluid thing and ended up letting one sit over night and still no luck the next day......I asked my wife to get me a can of Coke.....I poured it on and let it sit for about 30 seconds and then tapped with a rubber mallet......Problem Solved!
  5. Sep 18, 2009 at 8:39 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I had this same issue when I wanted to clean my rear brakes. If you look at the brake drum, you can see some holes with threads in them, I bought a bolt from Home Depot and put it through the thread. As you tighten the bolt, the drum should start coming off.
    I don't recall the size of the bolt.
  6. Sep 18, 2009 at 10:08 AM
    nighthawk87
    nighthawk87 Well-Known Member
    get a flathead screwdrive and mallot, hit the back of it till it pops off. Or got to the gym more :)
  7. Sep 18, 2009 at 10:25 AM
    corona56
    corona56 Well-Known Member
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    Added fog light mod Added delay wiper mod Alloy rims with BF Goodrich tires
    Other ideas.
    Use a mallet and hit the sides of the drum to try and force the shoes a little off the drums.
    Open the bleed screw on the wheel cylinder (you might need a quick bleed after this, however).
  8. Sep 18, 2009 at 1:25 PM
    Warren Thompson
    Warren
    Elko, Nevada
    Thanks all. I banged and banged, cursed, banged some more. It never broke free, so I gave up. Sprayed all the pene fluid off with brake cleaner, wire brushed them, sanded them, sprayed them black, and enjoyed the rest of my day. There are some great ideas posted here, but I just did not have the time to @^%$ with it anymore. I still do not know the condition of my brake pads though.
    BTW, the traction bar mod using Superior helper springs (no rivet) REALLY does make a difference in stability and cornering. I recommend this very highly!!
    The black brake drums are just... cool (I painted my front calipers red last weekend).
  9. Feb 14, 2010 at 8:25 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    I had this very problem today. Worked on them for hours! :mad: There was a lot of rust between the center of the drums and the flange in the middle. I found that spraying it good with penetrant and taking a large flathead screwdriver and inserting it around the edges and twisting it finally did the trick PITA! Better wear some decent gloves too. I've got blisters on my hand from this! :eek:
  10. Mar 20, 2010 at 1:37 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    No their is a much easier way to do this...
    Their are two small holes in the drum that have threads on them
    The thread is 8MM 1.25
    Go buy two bolts that thread size about 3 inches long
    Spray just a little penetrating lubricant into the threaded holes (PB Blaster)
    Thread the bolts in each threaded hole in the drum few turns each bolt
    making sure your getting the drum to slide off evenly
    After you see the drum almost off ,loosen up those two bolts again and pull the drum off with your hands
    Toyota was thinking on this one:D
  11. Mar 20, 2010 at 5:38 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    +1.
    The bolt method is just so much easier than banging away.
  12. Mar 20, 2010 at 5:42 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    ^^^^^ the BFH is not always the best route.. the 2 bolt method will force the drum off.
  13. Mar 20, 2010 at 5:54 PM
    TimS
    TimS Well-Known Member
    Tim
    Maine
    2010 DC tacoma/2005 access cab
    Rebuilt with flatbed 5100's, new spring packs
    Use the bolt method. Many manufactueres have this. Also, try a little heat from a torch. I've used both together and always got them off.
    Taking your drums off at the 30,000 mile service should be done just so you know they will come off in the future.
  14. Mar 21, 2010 at 6:25 AM
    blazze2005
    South Jersey
    took mine off yesterday...Holy brake dust!
    Sprayed with brake clean,light sanded shoes and inside drum,painted drum flat black
    I think I need to adjust them though..Don't think I have enough drag on the back wheel
    Anybody know how much drag should be on the back wheel or how I can go about adjusting them?
    I know that's what the adjuster wheel is for but not sure what direction to turn it to tighten up the rear shoes?
    Thanks for any info...
  15. Sep 21, 2010 at 3:17 AM
    fjrmurph
    fjrmurph Well-Known Member
    One thing to remember, coat the axle whare the drum sits with never seize, this will make it much easier the next time you need to remove your brake drums. Anything i take apart i coat with "never seize" before i reassemble
  16. Sep 26, 2010 at 5:44 PM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    I'm new to the Taco and I have not had a vehicle with drum brakes in 20 years.
    You should tighten the rear shoes until there is enough drag on the drum that you have to put a little force into it to turn them. This means the shoes are seated against the drum just slightly and they will wear off the little bit of excess quickly.
    You can only turn the adjuster easily, one way, it has a locking clip on it to keep it turning in one direction so it dose not back off while you are driving.. I believe from looking at my rear brake a few weeks ago that you will put the tool into the slot on the back plate and start with the tool end pointing down into the slot then push down on the handle to roll the star wheel.
    discaimer: it could be the other direction but you will find out real quick if nothing is happening.
    I hope his helps.
