Help with rear brake lights
Discussion in 'Lighting' started by davidc, Jan 15, 2010.
  1. Jan 15, 2010 at 12:06 PM
    davidc
    davidc [OP] New Member
    01 PRERUNNER
    Aftermarket rear brake lights not working checked all fuses and wires still not working
    2001 toyota prerunner
    4 cylinder
  2. Jan 15, 2010 at 12:39 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    do you have power and ground at the plug with the brake lights on?
  3. Jan 15, 2010 at 1:22 PM
    davidc
    01 PRERUNNER
    yes used a test light and it lit up when we hit the brake pedal
  4. Jan 15, 2010 at 1:35 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    it may be a bad bulb if you have power and ground at the light socket.did you ground the test light to the socket or to the truck?
  5. Jan 15, 2010 at 2:31 PM
    davidc
    01 PRERUNNER
    grounded it 2 the truck? was that right? we put new bulbs in should i ground it to the socket?
  6. Jan 15, 2010 at 2:36 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    no,what i'm trying to say is, you said you had power to the bulb,make sure you have a ground,which would be the other wire.
