Help with rear leaf mounts
Discussion in 'Long Travel Suspension' started by Conman117, Jul 3, 2012.
  1. Jul 7, 2012 at 11:16 AM
    Conman117
    Conman117 [OP] AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    hmm. I'll check it out when I go back in on monday. right now the centering pin on the leafs is plumb with where the stock bump stop was (I cut it off) when the leafs are like they are in the pic. so they will move back 1-2 inches? I can put my new bumps back a bit from stock. I got a measurement to the center of the wheelwell and I'm pretty close. I guess I'll cycle it soon with just one leaf and see how it is. I'll keep you posted.
  2. Jul 7, 2012 at 1:48 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Don't forget to set your pinion angle the right degree too.
  3. Jul 9, 2012 at 8:42 PM
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    So... What would that be? :D I've had a couple people tell me some different things, but what do you recommend?
  4. Jul 10, 2012 at 6:13 PM
    noSKills858
    Alex
    Poway, CA
    2-3 Degree's below inline with drive shaft.
  5. Jul 10, 2012 at 10:32 PM
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    Cool. I think mine is tacked at about that, at ride height. I'll do a final measurement when I'm putting it together and weld it fully then. thanks for the info.
  6. Jul 12, 2012 at 8:39 PM
    noSKills858
    Alex
    Poway, CA
    Let's see the final product there chief.
  7. Jul 12, 2012 at 10:41 PM
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    K I'll get some pics soon. Turns out one of my mounts is crooked so I have to fix that first. The frame is all painted so stuff can start going on permanently. Also the U-bolts I got with my giant kit are for a tacoma (duh) and don't fit on the tundra axle. Derp:p so I have to get some new ones.
  8. Jul 12, 2012 at 10:53 PM
    noSKills858
    Alex
    Poway, CA
    Funny enough after going through my u-bolts, I reverted back to stock since they were super long. They worked like a charm except when I bent them.
  9. Jul 12, 2012 at 11:04 PM
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    My stock ones are square though, from spring over. Also I may have cut one to get them off.
  10. Jul 12, 2012 at 11:28 PM
    noSKills858
    Alex
    Poway, CA
    Ooops for some reason I thought you had a 5-lug, my mistake.
  11. Jul 13, 2012 at 3:01 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    No....it should still bump in the stock location, if it didn't you would have to modify the driveshaft length.
    Take leafs apart, use main leaf and put it at full bump with the front hangers attached
    Center the leafs on the bumpstop, tack weld the front hangers in place
    Measure from the front hanger bolt to 52.5'' back and mount top shackle mount.
    Cycle everything with driveshaft attached, make sure it all works then weld it up!
  12. Jul 13, 2012 at 8:17 AM
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    Everything is all welded all ready. Only the spring perches are tacked in case I need to change the angle.
  13. Jul 13, 2012 at 10:50 AM
    TC yota
    Tyler
    Escondido
    Ha
    well I hope you didn't push the bump back like he said
  14. Jul 13, 2012 at 11:25 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Leaf spring ditcher :p Im guessing your linking yours?
  15. Jul 13, 2012 at 12:05 PM
    #35
    TC yota
    Tyler
    Escondido
    Ha
    After snapping two packs completely off the truck, I don't have a choice, haha
  16. Jul 13, 2012 at 5:25 PM
    #36
    noSKills858
    Alex
    Poway, CA
    My stock bumps would always hit on the rear edge never the center. That's why I had that spacer welded to the bump to move it backwards so it would hit square.
  17. Jul 13, 2012 at 9:27 PM
    #37
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    I'm gonna finish my front setup first, because I'm closer on that, then I have to rebuild my brakes in the rear, and I'm waiting on U-bolts. But the leafs are in and I have all my parts so hopefully I'll have it set up soon.
  18. Jul 16, 2012 at 6:38 PM
    #38
    noSKills858
    Alex
    Poway, CA
    If you went off the measurements I gave you from the frame cut out to the front bolt I assure you that it will work perfect. Did an F67 pack install on another members truck a few weeks back and he has since then been out to the desert twice.
  19. Jul 16, 2012 at 9:03 PM
    #39
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    Sure did. 29.5" from the front of the cutout to the center of the bolt of the front hanger, and then magic 52.5".
  20. Aug 3, 2012 at 7:40 PM
    #40
    nhurt
    nhurt Well-Known Member
    N8
    San Diego, CA
    98 5 Lug
    total chaos, Fabtech spindles, F67 deaver leafs, dual spares, hella black magic's, 55w HID's, sound system, AEM intake, magnaflow, pacesetter headers, electric fan, optima battery, tach, oil water temp and voltmeter gauges, 4.56 gears, loc-rite locker,
    battlescars did my F67 install as mentioned above, came out great heed his advice, he knows whats up for this install.
