Help with Rear Locker???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by squatnbear, Jul 7, 2013.
  1. Jul 7, 2013 at 11:46 AM
    squatnbear
    squatnbear [OP] Well-Known Member
    TX pro MGM
    Hello everyone,
    Sorry if this is in the wrong section but I needed some help.
    I own a 2011 TX Pro and took it out to play a little. I use 4 high and 4 low everything worked great. However my issue is with the locker. I fallow all the steps to put the truck in 4 low and then push the locker. The lights blink but nothing happens no locker. I jumped on TW and read to let it move a little to engage. Wouldn't you know it it worked. As I read the manual it should engage when its stopped or am i reading this wrong? Ok on to the 2nd question after the locker has engaged I tryed to turn it off. I stop and push the button but the locker stays on. I could not find anything about this anywhere online. So this is what I did, I drove with it a little and it disengaged. Is this normal? I am very new to lockers so any help would be great. Thank you all !!!
  2. Jul 7, 2013 at 11:50 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yes and yes. Stop and if won't engage/disengage roll forward or backward very slowly, if necessary you may need to turn the steering wheel while you roll.
  3. Jul 7, 2013 at 12:28 PM
    squatnbear
    TX pro MGM
    THANK YOU SO MUCH!!!
  4. Jul 8, 2013 at 3:17 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I would add to be very sure the clutch pedal is all the way to the floor and not simply depressed part way.
  5. Jul 8, 2013 at 3:26 PM
    4x4yota
    4x4yota 4wd is awesome
    Collin
    PA
    02 trd stepside v6
    The clutch shouldnt affect the locker to my knowledge. but it is very to true have the clutch all the way in for when switching into 4wd.
    And to answer the op's question yes its normal. Sometimes the locker will engage not moving(its rare but it does happen if the gear are lined up) but most of the time u have to move a little bit to get it to engage. Reason being is the locker needs to line up and see no resistence
  6. Jul 8, 2013 at 3:51 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Usually I have to be rolling with my tires turned to get my locker to engage.
  7. Jul 8, 2013 at 4:27 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Spot on.
