Help with rear shock plz.. mahalos
Discussion in 'Hawaii' started by TRDOFFROAD14, Dec 13, 2019.
  1. Dec 13, 2019 at 9:06 PM
    TRDOFFROAD14
    TRDOFFROAD14 [OP] Well-Known Member
    Manny
    Lanai city hawaii
    2023 tacoma 4x4 offroad
    Hey guys wazzup.. i have a 2014 tacoma offroad with a level lift kit, 3” front and 2” rear blocks with the stock shocks.. when hitting a small ditch my rear sounds is fully extended.. so i need ur guys help on rear shock.. im looking at a freedom shock from extreme terrain and its a 0-2” lift but thrs a 0-3”.. does tjis matter or same?
  2. Dec 13, 2019 at 9:32 PM
    DEDAFLO670
    DEDAFLO670 Well-Known Member
    Manuel
    Waipio
    15 Trd sport
    Yes an no, depending how much down travel an up travel you have on you rear I would go with 3, but if it’s just a daily the 0-2 is fine
  3. Dec 14, 2019 at 8:50 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    kinda confused.. you said when hitting a small ditch, your rear sounds fully extended. Could you please explain? If hitting the ditch, the shock would actually be in the compressed rather than the extended.
    I used to run the extended 5100s in my old truck. Had to make sure the shock didn’t bottom out when compressed (some may need to adjust bump stop)
    again, kinda need clarification on what your situation is. Plus. If you are hearing a loud sound it may not be your shock and possibly something else. Try tightening up the bolts on the rear. (Where your blocks are)
    seoulja99 likes this.
  4. Jan 12, 2020 at 9:58 PM
    TRDOFFROAD14
    Manny
    Lanai city hawaii
    Im on stock rear shocks with a 2” rear blocks..
    Sorry my bad,, yea hitting a ditch it compress and it extend to a sound ,, not sure what it is.. i just ignore it
  5. Jan 12, 2020 at 11:51 PM
    raycie
    Oahu, HI
    In need of $$$
    I would still torque your U-Bolts. If you are on blocks, and still have your bump stops in, I would be surprised if you are bottoming out your shocks.
