Help with rear suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rusteenutz, Nov 23, 2013.
  1. Nov 23, 2013 at 12:42 AM
    Rusteenutz
    Rusteenutz [OP] Active Member
    Georgia
    08 TRD OFF ROAD
    Maxtrac spindles, rear extended bilsteins, color match grill, touchscreen radio,moto metal 951 16s,
    Major vibes after 3" block. Looking at axle shims. What degree d I need for 3" blocks?
  2. Nov 23, 2013 at 4:22 AM
    Rusteenutz
    Georgia
    08 TRD OFF ROAD
    I read on here the cb drop is more for high speed vibes. So I should go ahead and do the cb drop first? Then try shims or the opposite?
    Also, the blocks have a slope in them. Do they slope downward toward the front or toward the back of the truck?
  3. Nov 23, 2013 at 7:55 AM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Generally a slope would go up towards rear of vehicle, but 3" block.....i personally wouldn't run that on my tacoma. Crappy ride, axle wrap, etc, etc
  4. Nov 24, 2013 at 1:27 AM
    Rusteenutz
    Georgia
    08 TRD OFF ROAD
    So am I better off doing toytec 3" aal?
  5. Nov 24, 2013 at 1:33 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  6. Nov 24, 2013 at 1:41 PM
    Rusteenutz
    Georgia
    08 TRD OFF ROAD
    Ok read up on the thread. Thanks for that after all the searching I didn't see that one. I've got the cb kit in and shims on the way. My leaf looks like shit! Guess this is axle wrap? Looks like an "~" instead of a "u".. So should I go with the add a leaf now or should I just go down and buy some clamps (I've seen this as an easy fix). It will be another week before I can get the aal too. Is it gonna hurt that much to drive around for a week like this?
    Thanks again guys for all your help
  7. Nov 24, 2013 at 1:44 PM
    Rusteenutz
    Georgia
    08 TRD OFF ROAD
  8. Nov 24, 2013 at 2:09 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Ya, that's caused from axle wrap. I wouldn't be surprised if you break a main leaf. Be easy on the throttle if you drive any more like that. Do it right and order a set of replacement 3" lift springs from deaver or alcan. Shims won't fix bent springs.
