Help with reinstalling camper shell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Aug 13, 2021.
  1. Aug 13, 2021 at 9:59 AM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I took my shell off to fix the damn leaking brake light and the cheap foam weather seal was totally flat. I pealed it all off and replaced it with the bulb type seal (https://smile.amazon.com/gp/product/B00NCC0SY6/). However, it's not sticking well. Really hard to clean the fiberglass. There seems to be some overspray from the glue they used to attach the carpet and it really grabbed the original weather seal too. Ended up pealing a bunch of that overspray adhesive off too.
    That seal is also a bit narrow (1 1/2"). The wider stuff is for a heavier shell so maybe it's fine but if there's a better one please advise.
    I have to pull it again to replace the light (it was broken not just bad seal) so I want to do it right this time. Should I apply some sort of spray adhesive under the weather seal so it will hold better? If so, what would be best?
    Also, the back window doesn't seal very well. Maybe it never did but now that I'm paying more attention I noticed it. Is there a good way to fix this? I tried some of the leftover bulb weather seal, but the gap is huge and the stuff doesn't fill it. It's possible I have the shell too far forward so I can slide it back some but I still think this gap will be there given how the shape isn't the same as the tailgate.
    Appreciate any feedback.
  2. Aug 13, 2021 at 4:05 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    So just to be clear, by "help" I wasn't looking for someone to physically help me remove/reinstall :)
  3. Aug 13, 2021 at 4:09 PM
    Pongo
    Pongo Well-Known Member
    Scott
    2016 Inferno Tacoma TRD Sport
    Is it the right Shell? I've never seen a gap in the rear that big to the tailgate.
  4. Aug 13, 2021 at 4:13 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    That shell seems to be sitting too high. Most caps don't have that much of a gap between it and the body.
    Do you have a photo of the before?
  5. Aug 13, 2021 at 4:17 PM
    xndak
    xndak Well-Known Member
    2023 Off Road
    I have an ARE topper and the rubber sweep on the topper lid rides on the paint below the plastic shit. That is way high. Properly seated you still have a 3/4 gap on both ends of tailgate/topper lid connection. Fixed mine by building up the sweep with more rubber and then using foam on the tailgate plastic itself
  6. Aug 13, 2021 at 4:18 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    Something is not right. That thing ‘s sitting WAY too high.
    Did you accidentally leave a typewriter, crock pot, or small child on the bed rail when you put it back on…?
  7. Aug 13, 2021 at 4:18 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    It's the cap I ordered for the truck so no reason to think it's the wrong one.
    I don't think I have a photo of that exact spot. It's probably a bit higher due to using the bulb type weather seal.
  8. Aug 13, 2021 at 4:20 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Yeah that’s sitting way to high.
  9. Aug 13, 2021 at 4:20 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Around the bed sides it's just a 1/4" to maybe 1/2" higher than before due to the thicker weather seal. Maybe it's too far forward and the door isn't closing down all the way.
  10. Aug 13, 2021 at 4:21 PM
    MNMLST
    Earth
    What brand cap..?
  11. Aug 13, 2021 at 4:21 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    ARE
  12. Aug 13, 2021 at 4:24 PM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Is the cap designed to sit on top of the bed rail or slightly covering it. There are two styles.
  13. Aug 13, 2021 at 4:24 PM
    MNMLST
    Earth
    My GUESS is that thing is cut to fit, with just the thin, open cell foam tape.
    It ain’t ever gonna be right with twenty feet of black mamba bulb seal crammed under it.
    Sorry.
  14. Aug 13, 2021 at 4:25 PM
    xndak
    2023 Off Road
    its just like mine and the very edge of the bottom door rubber seal should be riding below the top of the endgate plastic on the truck paint. Does the door operate properly?
  15. Aug 13, 2021 at 4:26 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Not sure. It originally came down closer to the metal but there was still a gap and you could see the bed rail.
    jwctaco[QUOTED] likes this.
  16. Aug 13, 2021 at 4:27 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Yeah, door works fine. Might be a tad tighter to rotate the handle. I think I'm maybe 1/4" too far forward, but I don't think that's going to fully seal even if slid back some.
  17. Aug 13, 2021 at 4:28 PM
    xndak
    2023 Off Road
    You can seal it with weatherstripping - just have to get creative...
  18. Aug 13, 2021 at 4:29 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    So should I put some thin weather seal under instead? I though the bulb seal was supposed to be better and partly because it did sit just a bit higher and helped to keep the cap from rubbing the sides of the bed.
  19. Aug 13, 2021 at 4:30 PM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Yep, you’re cap is designed to sit on top. The bulb seal is not going to work, to thick. Replace it it with better “thin” foam tape seems to be the solution.
    Edit 1/4” thick closed cell foam tape is what I used on my old truck.
    MNMLST likes this.
  20. Aug 13, 2021 at 4:32 PM
    xndak
    2023 Off Road
    Me too. I was going to do the same thing you did..
