Help with replacing shifter cover slide?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jthatcher, Nov 7, 2015.
  1. Nov 7, 2015 at 1:13 AM
    jthatcher
    jthatcher [OP] Member
    James
    DFW, TX
    06 Prerunner SR5
    Hey guys,
    I need some help with replacing the shifter cover slide (part # 35975) (Diagram http://www.toyotapartsoverstock.com...ukey_trimLevel=18360&searchString=slide+cover ) doesnt really clarify very well how to get the housing apart. its a 1st gen 99 prerunner. It broke a while ago and finally got the part in today to replace. Problem is finding instructions about the disassembly of the shifter are difficult. Everything comes up as 2nd gen, or manual when you search for it.
    TIA,
    James
  2. Nov 7, 2015 at 2:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Are you replacing the whole shift tower...?? If so it's pretty easy..
  3. Nov 7, 2015 at 7:00 PM
    jthatcher
    James
    DFW, TX
    06 Prerunner SR5
    I got it installed and figured out today, looks and functions great. i got the auto shifter off and the OD switch out it was pretty straight forward. The hardest part was the OD switch re install.
    When i was in there I saw one of the bushings on the shifter linkage was broken on the passenger side of the assembly. Seems like its pretty common
