help with retrofit headlights....
Discussion in 'Lighting' started by i2andom81, Apr 16, 2010.
  1. Apr 16, 2010 at 7:44 AM
    i2andom81
    i2andom81 [OP] Well-Known Member
    Denver
    08 black prerunner
    Fox coilovers and resi rears, 20% tint, wet okole trd seat covers, LCE engineering headers, custom magnaflow exhaust, afe cai, satoshi grill, URD supercharger, retrofitted headlights, weather tech mats, standard duty leafs, allpro front bumper and uca
    After the install of my retrofits everything worked fine. now my brights dont work. the lights turn off when i flick the high beams on. the high beams worked once and then never again. the lights work fine in the low beam position btw. anyone know the fix and how to do it?
  2. Apr 16, 2010 at 9:34 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Which wiring harness are you using? You have to remember, the stock harness has 3 ports. 1 low beam, 1 high beam, and 1 ground. When you have your low beam on, and then flick to high, the lows go off and the highs come on. So basically now that you have a retrofit, your HIDs go off, and the shield opens.
  3. Apr 16, 2010 at 10:41 AM
    i2andom81
    Denver
    08 black prerunner
    i have the h4 wiring. i think something went wrong somewhere because i used the high beams once and then they never worked again
  4. Apr 16, 2010 at 2:26 PM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Sierra Vista, AZ
    same exact thing happened to me and it took me 2 hours to figure out that i blew the high fuses in the fuse box.......
    Check those, probably the issue.
  5. Apr 16, 2010 at 2:29 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  6. Apr 16, 2010 at 2:51 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    :thumbsup:
    you just have to wire it up correctly w/ a diode. when the highs are selected, the low beam is no longer powered. therefore, if you harness is setup to power the ballast w/ the low beam wire only, when you flick the highs, you will no longer be powering the bulb (this is why the OP's bulbs work fine on low beam, but turn off when the highs are selected). you need a diode between the high and low wire (IIRC) to ensure the ballast is always powered no matter hi/low beam.
  7. Apr 27, 2010 at 2:33 PM
    i2andom81
    Denver
    08 black prerunner
    the fuse was blown. switched them out and good to go! thanks that was a painless fix
  8. Apr 27, 2010 at 2:40 PM
    TRDguyKC
    Kris
    Sierra Vista, AZ
    i knew it! it took me 1.5 hours to figure that out. glad i could help dude.
  9. Nov 15, 2010 at 8:59 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    weird problem with my D2s retrofit right now, some times when I turn on my headlights, nothing comes on, but when I turn the high beams on, the bulbs turn on. This is weird because high and low beam is on the same bulb for D2s so if high beams work, i know the low beam should work. Is there a known problem with the retrofit source harness not working correctly over time?
  10. Nov 16, 2010 at 9:12 AM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    Guys. To solve a lot of your problems and gain performance out of your retrofits, you should really make your own wiring harness that gets power directly from the battery. Use a relay and feed power from the baterry directly to the balasts, and use the a source from your fuse box to trigger the relay when the light switch is on. Then use the high beam power from your oem light harness to trigger the solenoid on the projectors for the high beam.
    Using power from your OEM harness will work, but the wires in the factory harness are small and not meant to push that much power through.
    I've done many retrofits and used plug and plays kits before. When you make a custom harness using direct power, your light output will be noticeably brighter.
  11. Nov 16, 2010 at 10:46 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    did you ever get that TL? they are nice i saw that a while back.
  12. Nov 16, 2010 at 11:19 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    is this true? i just ordered a complete retrofit setup the other day from trs. i don't have a problem splicing a wire or two but i would not know where to start when it comes to making a wiring harness for hid's lol.
