Help with rotor removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ccutler1223, Jan 22, 2021.
  1. Jan 22, 2021 at 11:18 AM
    ccutler1223
    ccutler1223 [OP] Well-Known Member
    Southern Utah
    Hey all. I have a 2012 TRD off-road Tacoma. I’m changing out the rotors and can’t figure them out! I’ve tried beating on it with a hammer , pb blaster. The interesting thing is when I try the bolt removal holes, the bolts will thread hand tight, then after a turn or two with the ratchet, they become lose again. Am I missing something here? Thanks for any input!
  2. Jan 22, 2021 at 11:31 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Which way are you hitting the rotors? I've always had better luck getting rotors off by hitting the outside surface instead of the back side. It may sound counter productive, but it works.
    As for the bolts, my guess is you either have the wrong size bolts and / or the threads are stripped.
  3. Jan 22, 2021 at 11:34 AM
    ccutler1223
    Southern Utah
    Thanks for the response. I’ve been hitting the back mostly. I’ll try the front. Also I’m using a 12mm bolt from my skid plate, as I researched these would work on the forums here. So the threads may be stripped. Which that blows. Lol.
  4. Jan 22, 2021 at 12:10 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I assume you've already removed the calipers....
  5. Jan 22, 2021 at 12:35 PM
    ccutler1223
    Southern Utah
    Yes. Lol. In the short time since my last reply I’ve done the whole drivers side. Bolt holes worked perfectly. Passenger side ones have to be stripped. So I guess it’s time to go to pound town. Lol
  6. Jan 22, 2021 at 12:43 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Had to check since it's Friday and sometimes things get wild here on Fridays. lol
    Time to break out the big fucking hammer!
    ccutler1223[OP] likes this.
  7. Jan 22, 2021 at 12:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The rotor is probably rust to the hub.
    At this point you are right, you’ll probably have to resort to pounding it off.
    The next time, turn the bolts until they have pressure on them evenly and on both side.
    Don’t keep using the bolts to press the rotor off. Just get some pressure on them and then smack the rotor. Kind of like you do a ball joint. Think of the bolts as an aid to the hammer to help get rotor off.
    I generally use a dead blow hammer. But it really doesn’t matter if you not going to reuse the rotor. The dead blow hammer isn’t better. It’s just more forgiving when you “miss”.
    Let us know how it goes.
    winkel, Dm93 and ccutler1223[OP] like this.
  8. Jan 22, 2021 at 12:50 PM
    Too Stroked
    Tom
    Up here in the rust belt, nobody uses dead blow hammers on rotors. No substitute for a BFH up here. All day long I hear the guys around me blasting them off that way. The problem is, sometimes you have to beat them so hard - because they're rusted on so badly - that wheel bearings take a beating.
  9. Jan 22, 2021 at 12:51 PM
    TnShooter
    Deogee
    STOCK
    I don’t think I’d know what to do if I lived up North. Lol
    The South has me spoiled, we have it easy compared to you guys.
  10. Jan 22, 2021 at 12:53 PM
    ccutler1223
    Southern Utah
    Yeah I’m just going to have to get a bigger hammer. I’ll most like ruse a large rubber mallet hopefully “easing the beating on the wheel bearings”. Lol. Thanks for the tip
  11. Jan 22, 2021 at 12:55 PM
    ccutler1223
    Southern Utah
    Thanks for the help everyone. Going to seek out a large rubber mallet to help me finish the job. As I said above I got the drivers side done no problem. So we will get it! :thumbsup:
    TnShooter likes this.
  12. Jan 22, 2021 at 1:00 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    The rubber mallet is just gonna be destroyed. Get yourself a 3lb sledge and start beating.
  13. Jan 22, 2021 at 1:00 PM
    TnShooter
    Deogee
    STOCK
    I don’t think a rubber mallet is going to help.
    Just use a regular hammer.
  14. Jan 22, 2021 at 1:10 PM
    ccutler1223
    Southern Utah
    Should I hit the rotor directly or should I hit a 2x4? I don’t care about salvaging the old rotor, just don’t want to mess anything else up.
  15. Jan 22, 2021 at 1:30 PM
    Too Stroked
    Tom
    Our guys just hit the rotor directly with a 3 lb. sledge. A 2x4 will absorb too much energy.
  16. Jan 22, 2021 at 1:33 PM
    ccutler1223
    Southern Utah
    Cool. Thanks for the info.
  17. Jan 22, 2021 at 1:40 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    3LB ford wrench!
    Sometimes a50/50 mixture of acetone and ATF soaked into the area where the rotor and hub are fused together can help. A bit of heat from a MAPP cylinder after it soaks for 10 minutes can work wonders and you won't have to pound the snot out of the wheel bearings.
    Gunshot-6A and ccutler1223[OP] like this.
  18. Jan 22, 2021 at 1:52 PM
    ccutler1223
    Southern Utah
    Will give this a try. Thanks.
  19. Jan 22, 2021 at 2:03 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Yep directly. And like you mean it
    Too Stroked likes this.
  20. Jan 22, 2021 at 2:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Keep turning it while you hit it too, don't just keep hitting in the same spot.
