Help with rotors
Discussion in '1st Gen. Tacomas (1995-2004)' started by gshear6442, Oct 26, 2023.
  1. Oct 26, 2023 at 11:14 AM
    gshear6442
    gshear6442 [OP] Active Member
    Griffin
    97' Tacoma
    None
    I have manual hubs and cant get the metal part off the holds the rotor in place is there anything I’m missing?
    MikeWH likes this.
  2. Oct 26, 2023 at 11:19 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    only thing holding the rotor on is the lugs. Yours might be rusted to the hub and need more encouragement to come off.
  3. Oct 26, 2023 at 11:20 AM
    gshear6442
    Griffin
    97' Tacoma
    None
    Should I just use a mallet to knock it off
  4. Oct 26, 2023 at 11:21 AM
    0xDEADBEEF
    Yeah you probably could. Some pb blaster around the hub and the lugs wouldn’t hurt either.
    Andy01DblCabTacoma likes this.
  5. Oct 26, 2023 at 11:39 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Yup, pb blaster, encouragement from a mallet / hammer, and then heat...
  6. Oct 26, 2023 at 9:14 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    your manual hub studs have cone shaped washers that can be very tight. I haven't worked on a manual hub toyota in years, so someone else should chime in here with suggestions on how to remove those cone shaped washers.
  7. Oct 26, 2023 at 9:40 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    3-4 lb metal mini sledge as plastic deadshot hammer will not do much.
    You need rotors anyway.
  8. Oct 27, 2023 at 8:33 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I use my air hammer on the hub where it will not damage things it vibrates the cone washers out quit well .
    I have found this by far the best way I have ever found .
    Spraying your favorite penetrating spray also helps.
    Old metals and leid like this.
  9. Oct 27, 2023 at 10:23 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Put two lug nuts on for a few threads. Then hit with a hammer rotating side to side. It'll come off, just rusted to the hub.
    Get some antiseize for when you clean off the hub and the backside of the new rotor to prevent it from happening again.
    **Metal body of the manual hubs does not need to come off. But as mentioned the cone washers need to come off if you want to take that off.
  10. Oct 27, 2023 at 10:26 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Cone washers are keeping them on.
    Put the nuts back on the studs, and screw them on just enough to have both the nut and bolt flush on top.
    Take a brass drift, place it on said stud/nut and give it a few good whacks.
    One or two good ones, turn and do the same for the remainder.
    It'll start to pop off and it'll come right out.
    I've taken plenty off of Tacoma's being parted out.
    ToyRyd04 likes this.
  11. Oct 27, 2023 at 11:31 AM
    0xDEADBEEF
    I don’t think he’s trying to take the manual hub bodies off…
  12. Oct 27, 2023 at 12:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I forget the rotor opening is larger and completely slips over it :violent:
    He just needs to whack the rotor then.
    0xDEADBEEF[QUOTED] and Bivouac like this.
  13. Oct 27, 2023 at 12:14 PM
    Bivouac
    A puller to break things loose after being on there some time.
  14. Oct 28, 2023 at 6:13 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I did rotors on a Ford ranger once and had to give er' the business with a single jack, they were pretty stuck on there lol
