help with rough idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by apex9r, Nov 14, 2009.
  1. Nov 14, 2009 at 6:58 PM
    apex9r
    apex9r [OP] mountain rover
    '97 4x4 2.7 5spd
    starting from scratch
    irregular miss at idle which is around 700rpm. new plugs, newish wires, does octane matter in these trucks? I run 85:confused:
  2. Nov 14, 2009 at 6:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    How many miles? Is the CEL on?
  3. Nov 14, 2009 at 7:00 PM
    apex9r
    '97 4x4 2.7 5spd
    it was on a week ago with codes for #3 cyl missfire and o2 sensor. then i changed the plugs and reset the comp and the light stayed off. 149000k
  4. Nov 14, 2009 at 7:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmm......is it only at idle? How bad?
  5. Nov 14, 2009 at 7:05 PM
    apex9r
    '97 4x4 2.7 5spd
    it never dies but its quite irritating and noticeable. if i raise the rpm's by even 50 it runs smooth. could the idle be set too low?
  6. Nov 14, 2009 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Idle is electronically controled. Check for vacuum leaks, or disconnected vacuum lines.
  7. Nov 14, 2009 at 7:12 PM
    apex9r
    '97 4x4 2.7 5spd
    what about the cable adjustment on the throttle body? hmm vaccum lines do sound like the most plausible reason.
  8. Nov 14, 2009 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That wont make the idle rough. It should be smooth at that RPM with a slight "burble" now and then at most.
  9. Nov 14, 2009 at 7:18 PM
    apex9r
    '97 4x4 2.7 5spd
    well that "burble" is about every 2-3 seconds, and do you still have ur cummins?
  10. Nov 14, 2009 at 8:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope. I had to get rid of it.
  11. Nov 15, 2009 at 11:36 AM
    apex9r
    '97 4x4 2.7 5spd
    aww:( sorry bro, know the feelin:drunk:
  12. Nov 15, 2009 at 11:43 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  13. Nov 15, 2009 at 11:45 AM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    I have just recently developed a similar issue where the idle is low and rough around 500 rpm... it use to be a bit higher... thoughts?
  14. Nov 15, 2009 at 1:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Normal idle for the 1GR-FE after warmed up is 500 rpm or so.
