HELP with rough running in 2vz-fe
Discussion in 'Performance and Tuning' started by FreidTaco, Feb 23, 2014.
  1. Feb 23, 2014 at 2:52 PM
    FreidTaco
    FreidTaco [OP] boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Just bought a 1991 camry v6 manual with the 2vz-fe engine.
    Had been sitting for a couple of years.
    We just drove it 400 miles and ran heat and injector cleaner through it. WE have only been running premium gas.
    We are having troubles with getting the engine to run well.
    Idles fine.
    Engine runs rough from 1k to 3k
    Runs great at 3k to 4.5k
    Can not get it above 4.5k
    Even parked trying to rev it, it will not go above that.
    Redline is supposed to be at 6.8k
    Hard to get going, bucks and knocks below 2.5k
    Any Help would be greatly appreciated.
  2. Feb 23, 2014 at 3:10 PM
    FreidTaco
    jeff
    Anyone? We are currently driving through a blizzard.
  3. Feb 24, 2014 at 4:47 PM
    FreidTaco
    jeff
    Possibly narrowed it down to a timing issue. Fingers crossed. Above know what degree this engine is supposed to be running at?
  4. Feb 24, 2014 at 8:14 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Plugged cat? Dead O2s?
    i can't find anying timing info on it yet.
  5. Feb 24, 2014 at 8:20 PM
    FreidTaco
    jeff
    we did have CEL come on originally and did a manual check of the codes and they came up as a knock sensor (due to bad gas) and then a starter position sensor (wire was just poorly twisted together, fixed with solder). went away after 100 miles on premium gas and now no codes.
  6. Feb 25, 2014 at 11:18 AM
    FreidTaco
    jeff
    No one rents a dang timing light here in town.
  7. Feb 28, 2014 at 10:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So you let it sit for a few years with gas in it. Started it and drove it, and it ran bad? Separation of ethanol content in the gasoline. Be a very good idea to change the fuel filter as well. Very good idea.
  8. Feb 28, 2014 at 10:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not sure of your mileage, but this crud doesn't atomize or combust very well.
  9. Feb 28, 2014 at 12:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nah he bought it from someone. He didn't let it sit for years. The timing is way off too i guess. He bought it to make it into a 24 hour le mans car for fun.
  10. Feb 28, 2014 at 2:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    LeMons *** ;)
  11. Feb 28, 2014 at 2:32 PM
    FreidTaco
    jeff
    Yes we changed the filter before we purchased it. We put heet and fuel injector cleaner in tank before we even dove any place. Now has 600 miles on it with only premium. The other night
    I was messin with the timing on the distributor and noticed that the cap is maxed out to the advanced side. when you retard the timing in runs shittier and this was confirmed by a backfire through intake. What i am guessing that happened was that the cam gears that were in the trunk were replaced and or the belt with it. My guess is that the belt is one cog off (5*) off. and would potentiay prevent the timing from being advanced any more, that is why im guessing it runs decent with high rpm and 1/4 throttle cause that would advance the timing and would have the correct amount of fuel/air mix for a lower rpm but has little power because of little inputs and correct timeing.
  12. Feb 28, 2014 at 8:28 PM
    FreidTaco
    jeff
    well thats not good
  13. Feb 28, 2014 at 8:42 PM
    FreidTaco
    jeff
    crank is at 0*TDC and the even cylinder bank is line perfectly......
    the odd bank is fuckin us. off two teeth. hope there is no internal damage
  14. Feb 28, 2014 at 8:44 PM
    BamaToy1997
    Bill
    Navarre, FL
    There won't be. Those engines are non-interferance engines.
  15. Feb 28, 2014 at 8:45 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    :popcorn: You gonna give me a ride in this POS when you finish?
  16. Feb 28, 2014 at 8:49 PM
    FreidTaco
    jeff
    THANK YOU!!!!!!!
    Yes sir, we need to order some belts and various bits, along with some port and polish, and valve clearance double checking.
  17. Feb 28, 2014 at 8:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    This. You'll be fine.
    Frozen idle pulley haha what happened to my supra too
  18. Feb 28, 2014 at 8:58 PM
    FreidTaco
    jeff
    The shredding indication of that?
  19. Feb 28, 2014 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea..haha looks pretty bad. Get a new one of those and best ASAP.
  20. Feb 28, 2014 at 9:17 PM
    FreidTaco
    jeff
    What brand, DAYCO, DNJ ENGINE COMPONENTS, ITM, Gates, Goodyear, acdelco
