Help with Screech in Radio
Discussion in 'Audio & Video' started by RCOTaco, Nov 14, 2012.
  1. Nov 14, 2012 at 6:36 PM
    RCOTaco
    RCOTaco [OP] Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    I need some help here. I was doing this mod here to my stock head unit:
    http://www.tacomaworld.com/forum/au...ux-input-05-stock-head-unit-overrides-fm.html
    Well, I got to the part about removing the resistors, and on the very first try, I messed up my resistor. So, off to Radioshack I went, hoping I could replace them. I got two packs of resistors, one pack was 1 watt 10 ohm, and the other pack was 1 watt 100 ohm. Well, I continued the mod, using the 10 ohm resistors. Plugged everything back into the truck, and there was this screeching noise coming through my speakers. I can hear the radio playing faintly, and when I plug my iPod up, it will override the radio, and I can faintly hear it. The whole time, this quiet screech is accompanying the music.
    So I decided to take it apart, and try the 100 ohm resistors. Replaced them, put the radio in the truck, and the quiet screech is still there. This led me to believe that it isn't the resistors that are causing the problem. Because with both of the different resistors, the same thing happened.
    Can someone help me out here, and give me some insight into what is causing this screech? It isn't that "nails on a chalkboard" screech, it's more like a constant ring-type of screech.
    Any input, positive input is welcome!
  2. Nov 14, 2012 at 6:41 PM
    teamamerica
    teamamerica Get off your horse and drink your milk.
    Wy
    2009 tacoma
    none yet
    do you know what size the old resistor was? maybe the one you put in was too low and fried a circuit? (i'm not an electrician though)
  3. Nov 14, 2012 at 6:46 PM
    RCOTaco
    Dalton
    Hamlet, NC
    At first I didn't think about busting out the multimeter, so I just started with the 10 ohm resistor. I was told that as long as I didn't go higher than what the circuit is rated for, that it wouldn't hurt the radio.
    Then it hit me to test the old resistor with the multimeter. It read right at 93 ohms. It was damaged, so I thought that might account for 7 ohms. Therefore, I tried using the 100 ohm resistor, and that still left me with the same screech.
  4. Nov 14, 2012 at 7:36 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Are you sure you have good solder joints? I don't know honestly, but it sounds like you don't have the right resistor. I'd PM the guy who did the mod and ask him for his take on it. Chances are the resistors are higher quality in the head unit, I think all radio shacks shits around 5%
  5. Nov 14, 2012 at 7:55 PM
    RCOTaco
    Dalton
    Hamlet, NC
    I'm 99.9% positive the solder joint are good, especially since I had to do it twice. I may go back and do it again just to make sure though! And you are right about the quality of Radioshack components, they're 5%
  6. Nov 28, 2012 at 12:33 AM
    brian
    Elizabeth City, NC
    Any luck?
